Old 05-11-2013, 10:50 PM   #11
Phat Phrog Stunt Crew
awwall's Avatar
Originally Posted by BigJohnD View Post
I would go to the dealer, but I've managed to stay away from them at all costs over the years. I've never found a real good one that did things like I wanted, or didn't fix one thing and break two more things. Shame on me for being a perfectionist. I did bring it up to Indiana for a few fixes on the slideout and some other issues. I wanted to tour the factory and get stuff done by FR, kill two birds with one stone. The RV is new, purchased in January. However, even if it costs me a little, I'd rather fix it myself. I can't even count how many things I've redone on this motorhome to bring it up to our standards I've learned pretty much how to be my own Rv Tech through the forums, experience and school of hard knox. Can't beat the forums, as shown in this thread, I have opinions and answers within a couple of hours. Can't get that at a dealer. I haven't left my easy chair. Since I don't have much experience with the refrigerators, since I've never had a problem, I've turned to yall, which have given some good feedback. Thermistor or PCB, narrowed down enough to get somewhere. Thanks to all and I'm still open to any other comments.
BigJohn, your are my kinda man. I too go to the dealer as a last resort. Have had my coach for almost a year and they have not touched it other than to fix a rubbing AC fan. Done this because I was passing right by the dealership.
In your endeavor to fix this, you may want to look here. This seems to be a good alternative to the original thermistor. They have the boards also.
Dometic Thermistor Repair Kit
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 05-12-2013, 11:33 AM   #12
VinceU's Avatar
Agreed, I used a dometic dealer who can be a HVAC shop familiar w/RV stuff. Remove a 200# box was was outside my workscope!
VinceU is online now   Reply With Quote
Old 05-12-2013, 12:05 PM   #13
B47
Originally Posted by dalford View Post
I agree with Vince that it could be a bad thermistor but when I had a thermistor go bad on my boat the temp got hot. Anyway, I came across this troubleshooting guide the Dometic units. Maybe it will be of some help. Good Luck... Don
http://www.fourwheelcampers.com/newd...atormanual.pdf
Why oh why can't Dometic put a simple photo and information in their manual about the Thermosistor (sp)?
Yes they mention it in section 5, but that pertains to testing it.
I for one was never told about this feature until we brought our FW back to the dealer and the service manager told me " all you have to do is push this thing up so it touches the freezer bottom".
Old 05-12-2013, 12:15 PM   #14
B47, read further...Section 5.2 states:
Disconnect the thermistor harness from the P2, 2-pin ter- minal on the lower circuit board. Place the thermistor in a glass of ice water (more ice than water), approximately 33° F to 35° F. Wait 8 to 10 minutes. You should get a reading of approximately 8,000 to 10,000 ohms. Always test from the wire side as shown with the meter as not to
create a connection problem at the P2 connector.
It even shows the location of the connector..
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 05-12-2013, 12:19 PM   #15
B47
Yes I mentioned that, but it only pertains to testing it. A person shouldn't have to test it before knowing what it does and where it is and looks like.
Just a simple photo and explanation of it, similar to the control panel, would suffice for me.
Old 05-12-2013, 01:47 PM   #16
We have the opposite problem.
Our freezer does a great job at keeping things frozen.
But our fridge is a little warmer than I'd like. We have one of those cheap thermometers and during the day it gets to the top of the "ok" temp band. We really try to limit door openings and do it very quickly. The temp adjuster is all the way to the cold section. What is this trick of moving to another fin? It's on the right side now. Can moving it to a different fin make it even colder?
Thanks!
All previous rigs below are sold - waiting until the kids graduate to the buy the next one!
'13 Forest River Sunseeker 3100 Class C
'04 Fleetwood Sedona Pop Up / Reese Mini 350 / Prodigy / BAL
'94 Coleman Cedar Pop Up
paulmlac is offline   Reply With Quote
Old 05-12-2013, 02:32 PM   #17
B47
Thanks!
Not sure as ours is working ok with it on the far right fin as you look into the fridge and I think that is where it lays has been.
Some other posters here have mentioned doing it.
One thing - don't waste your time looking in the manual for any information about the placement of it - there ain't any
Old 05-12-2013, 07:21 PM   #18
BigJohn, my fridge does the same thing. I think its just normal for that unit. The tube attached to the plate that slides up and down the fins seems like a silly design. My fridge freezes everything overnight. I've slid the thing up and down, and moved the tube up and down. I miss the temp selector switch on my old Norcold. Just keep putting warm cans of beer in it to raise the temp.
4Gcampers is offline   Reply With Quote
Old 05-12-2013, 07:35 PM   #19
VinceU's Avatar
B47 I have to agree with you, I had 3 different Dometic fridges with the slide, by the time I learned to use it properly I ended up with the 5 step digital control in my present unit! Its true you need to keep the doors closed, all these units use lots of energy but they are not terribly efficient when compared to compressor cycles.
Old 05-12-2013, 07:38 PM   #20
Thanks!
Paul, I read in another forum that the fins get colder from right to left. I'm not sure how to say this but if the far right fin warmest temp is too cold it may signal to maintain too low of a temp. It won't hurt to move the thermostat assy to the next fin over and see if it has any effect.
You don't mention your model. Number but I assume it has the white plastic slider with the thermostat shoved inside. Just slide it off the fin and put it on the fin next to it and see what happens.
2016 Siverback 33IK
