Old 05-11-2013, 06:30 PM   #1
Plain Old Member
Fridge Temp at 29 degrees tops
Anybody have trouble with the Dometic fridge in their unit cooling too much? Mine will not get above 29 degrees. I have tried every remedy I have found on the internet. Slid the sensor all the way down as much as possible to the "warmer" section, moved it over to the left a couple of fins, put a fridge fan in there and so on. The thermometer is placed in the middle of the fridge. It starts building ice on the fins after 36 hours or so. After a couple of weeks the fridge and freezer have a nice chunk of ice in them. The gaskets seem to be sealing as good as can be. Enough to create a good vacuum. I used to only have to defrost these things every 6 months or so, now it's every couple of weeks. The motorhome is indoors on a level slab always hooked up to the electric. Any ideas? I'm about ready to trash it and put a residential and inverter in.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 05-11-2013, 08:20 PM   #2
DDC
DDC's Avatar
I had this problem earlier this year it is a real pain as I have to keep my insulin in it, It did start to work ok eventually after doing all the same things you have done.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 05-11-2013, 09:11 PM   #3
Plain Old Member
I'm doing some more testing, adjustments today, so we'll see if anything changes. In every RV we've owned, I've left the fridge on from purchase date to sale, with the exception of the occasional defrost. I've gotten so aggravated with this one, I was about to start shutting it off after ever trip to keep from having to defrost so much ice. I can imagine you were a bit aggravated, especially when medication is involved, and not knowing what the temp is going to do.
Old 05-11-2013, 09:40 PM   #4
VinceU's Avatar
Learned last winter quickest way to defrost is with a good hair dryer. 10 minutes for fridge, next day 10 minutes in freezer. Gaskets are important so is infrequent opening the doors, that's the source of frost. Dryer much quicker than any other method. Chiller drains will carry it away quickly, hand towel works in freezer while melting.
Old 05-11-2013, 09:46 PM   #5
Plain Old Member
VinceU, pretty much same way I defrost. Pack a towel in the freezer, also one in the fridge, hair dryer on "cool"setting since the extreme heat can damage some things. I also put rags or small towels under the fridge, outside panel removed as not everything makes it in the drain pan and out the tube. Some how it gets out between the fins and plastic and runs down the back of the fridge. Not a lot, just enough to be aggravating. Most every one I've had has done this.
Old 05-11-2013, 09:51 PM   #6
VinceU's Avatar
Darn, and I was going to add "inventor" to my masthead! But more seriously I'm thinking the thermistor or the main PCB is bad telling the fridge heaters to keep going, haven't reached set point yet. To prove it put the gas burner on instead of electric. See if it shuts off while on gas, and box temp if it does.
Old 05-11-2013, 10:07 PM   #7
Phat Phrog Stunt Crew
awwall's Avatar
Could be that the thermistor has gone bad or a bad control board. I see your Forester is new. Is it time for a trip to the dealer?
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 05-11-2013, 10:10 PM   #8
I agree with Vince that it could be a bad thermistor but when I had a thermistor go bad on my boat the temp got hot. Anyway, I came across this troubleshooting guide the Dometic units. Maybe it will be of some help. Good Luck... Don
http://www.fourwheelcampers.com/newd...atormanual.pdf
2016 Siverback 33IK
dalford is online now   Reply With Quote
Old 05-11-2013, 10:33 PM   #9
Plain Old Member
I would go to the dealer, but I've managed to stay away from them at all costs over the years. I've never found a real good one that did things like I wanted, or didn't fix one thing and break two more things. Shame on me for being a perfectionist. I did bring it up to Indiana for a few fixes on the slideout and some other issues. I wanted to tour the factory and get stuff done by FR, kill two birds with one stone. The RV is new, purchased in January. However, even if it costs me a little, I'd rather fix it myself. I can't even count how many things I've redone on this motorhome to bring it up to our standards I've learned pretty much how to be my own Rv Tech through the forums, experience and school of hard knox. Can't beat the forums, as shown in this thread, I have opinions and answers within a couple of hours. Can't get that at a dealer. I haven't left my easy chair. Since I don't have much experience with the refrigerators, since I've never had a problem, I've turned to yall, which have given some good feedback. Thermistor or PCB, narrowed down enough to get somewhere. Thanks to all and I'm still open to any other comments.
Old 05-11-2013, 10:42 PM   #10
Big John, I usually have a saying, "It only costs me a little bit more to do it myself!" but I agree with you when it comes to what I have seen in my short TT experience. The link I sent is very detailed. I guess the first thing I would check is to make sure the thermistor wires are connected or have been stripped before they were screwed down into the connector.
2016 Siverback 33IK
