Old 08-19-2013, 07:09 PM   #1
NCIC105's Avatar
Frig running on Lp
How long will the frig run off a full LP tank... We have the double door frig with an ice maker...
Salesman told us frig would get colder faster running on LP...
NCIC105 is offline   Reply With Quote
Old 08-19-2013, 07:14 PM   #2
Fire Instructor's Avatar
We have a smaller fridge, but we went 11 days in 90F weather, cooking, hot water, and fridge, and used slightly more than 20 pounds....
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 08-20-2013, 07:37 AM   #3
MotocrossCamper's Avatar
Ours is also smaller but we went 6 on a little less then a half tank.
MotocrossCamper is offline   Reply With Quote
Old 08-20-2013, 08:10 AM   #4
Brother Les's Avatar
It may be true that the fridge will get colder 'faster' running on LP. But once it is 'down to' the max cold, why worry about the difference. If you need to run on LP going down the road, do it. If at a campground the 'auto' will move it over the 110. Save your LP for when you need it. 'water' to make ice takes the same amount of time to freeze with either LP or 110, (the freezer is the same temp). If you need 'ice' faster that the ice maker is 'making it'.... go to the camp 'Lodge' and buy a bag.
We average camping 40 days a year (traveling thousands of miles with the LP fridge on) and a one 30pound LP tank (usings 110 at the campground) will last us around 3 YEARS.
Brother Les
Old 08-20-2013, 08:22 AM   #5
I was stating mine because we don't stay in campgrounds. That's running your fridge 24 hours a day on propane. Also I'm going off the fact that my Sunseeker only has a 12 gallon tank (and I assume his is close to that). We don't have the luxury of dual 30's.
« AC Unit Model | Mpg »
