Old 05-05-2019, 09:20 AM   #1
Senior Gold Member
rthomaslyons's Avatar
Front and Rear Tire Pressures 3010 DSF
I just assumed when I brought our new Sunseeker 3010DSF home a week ago that tire pressures would be something the dealer would check during the PDI or for the safety of people test driving the unit. On the door jamb it clearly states. That front tire pressure should be 75 psi and rear pressure 80 psi. Upon delivery, the front tires were approximately the same at 62 psi and the rears between 55 and 70 psi with there bring 10 psi difference on the same tandem side. Interesting enough it looks like the Hancook maximum tire pressures 80 psi. What do you run your tires at?
Also the air bags contained no air and the manual says there should be T least 20 psi to prevent damage so I put in 25 just to be safe. Do RV dealers only worry about the part above the a axels or what...
rthomaslyons
2019 Sunseeker 3010 DSF
rthomaslyons is offline   Reply With Quote
Old 05-07-2019, 10:38 AM   #2
Senior Gold Member
I guess must be a non-issue for most people but I would be interested in knowing what tire pressures people find gives the best ride and stays within the specifications.
rthomaslyons
Old 05-07-2019, 10:59 AM   #3
PPST Wannabe
kenandterry's Avatar
Itís up to the owner to be vigilant on tire pressure.
Not sure how loaded you are yet with your new rig, but I suggest you fill the tires to the posted numbers to begin with. Do some significant driving and start judging for yourself.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is online now   Reply With Quote
Old 05-07-2019, 11:06 AM   #4
Tire pressure and handling
With regard to front tire pressure:
POPULAR MECHANICS MAY 1973:
START QUOTE:
If too little caster exists, the car will wander and weave,
thus necessitating constant corrections in steering.
END QUOTE:
There are at least two ways to increase the effective
runtime caster:
1. Decrease the tire inflation pressure to the required
minimum for load (to increase Pneumatic Trail), this
should give you the maximum available benefit from the
existing caster angle. It appears this effect is much more
pronounced on larger wheels (ie 22.5 inch vs 16 inch)
AND/OR
2. Increase the caster angle during an alignment
(to increase caster trail).
Harvard is offline   Reply With Quote
Old 05-07-2019, 11:13 AM   #5
Citrus County, Fl.
GL1800Rider's Avatar
On my 2016 3011 which has Michelin I run 75 front and 80 rear. I also run about 70 in the air bags which seems to give it a good ride. Weight wise we are maxed out.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 05-07-2019, 12:34 PM   #6
rvrobocop's Avatar
I have no air bags and am maxed out as well. I find that PSI to be the most optimum. After several hours on the road, the fronts will be 80-82 and the rears in the low 90s, unless it is unforgiving, hot weather.
Scott
2011 Sunseeker 3170DSF
2002 Honda CR-V
"Do not mistake my benevolence for weakness."
rvrobocop is offline   Reply With Quote
Old 05-07-2019, 01:07 PM   #7
Erinn
75 & 80, as stated on the door jam. Assuming you have the Ride Rite Air Helper Springs, the DH adjust them once in a while to get a nicer ride.
Dan and Erinn
2018 Forest River Sunseeker 2420MS
TOAD: Mercedes Smart Car
06/01/18-11/10/18 Camped 43 days!
SunseekerFunseekers is offline   Reply With Quote
Old 05-19-2019, 09:11 AM   #8
Senior Gold Member
What air pressure do you run in your air bags and how do you know what to adjust them to to improve the ride?
rthomaslyons
Old 05-19-2019, 11:37 AM   #9
Run 75 front and 80 rear in my Hankooks. Still like those tires after 8000 miles. 70 in air bags. Mine usually deflate to 40 between trips.
GMax is offline   Reply With Quote
Old 05-19-2019, 11:59 AM   #10
X2 60 in air bags.
AbdRahim is offline   Reply With Quote
pressure, tire
