Old 05-04-2014, 05:32 AM   #1
Mike & Molly's Avatar
Front/Bedroom TV
After channel scanning/programing the front TV in our 3010DS, we receive
22 local channels (over the air not cable). When scanning the TV in the bedroom we only get 2 channels. The two TV's are connected to the same roof antenna. Both are Jensen TV's. Only the size is different. Any guess's what might be wrong/where to look. BTY, both worked perfectly last season. Thanks for any help.
Mike & Molly is offline   Reply With Quote
Old 05-04-2014, 09:53 AM   #2
I hope one of the smart members on here has an answer, because I have the same issue.
Rocket City Gary is offline   Reply With Quote
Old 05-04-2014, 03:54 PM   #3
Make sure the amplifier button is on. You will find the little red pushbutton right below your primary TV (probably front. Push it in and rescan.
Bob & Sue Rowan
Okeechobee, FL
2012 Coachmen Mirada 29DS (SOLD)
2015 Keystone Bullet Travel Trailer
2016 F-150 Lariat with Auto Trailer Backup
Dog = Morki (Yorkie-Maltese) - Zoe
Malabarbob is offline   Reply With Quote
Old 05-05-2014, 05:13 AM   #4
Also make sure that you are scanning "air" channels and not "cable" channels. Usually on the scan menu you can select one or the other. If its set to cable, you won't find but a couple of channels.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 05-05-2014, 11:33 AM   #5
GM
bclemens's Avatar
Try all those things...then check for loose connections.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 05-05-2014, 03:26 PM   #6
Did it ever work before?
Make sure the air selection switch is depressed on the switcher if you have one installed.
Loose wiring?
Sent from my SCH-I545 using Forest River Forums mobile app
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
Old 05-05-2014, 05:16 PM   #7
I'm headed out on a trip on Saturday and will try again. I don't think I have an amplifier button on my Forester 3151. I do have a switcher and always depress air before I scan the bedroom TV. If someone has a Sunseeker 3050 or Forester 3151 and have an antennae amplifier button then please tell me where it is.
Old 05-05-2014, 05:44 PM   #8
tmhyer's Avatar
I have a sunseeker with the cab over entertainment. My button is locayed by opening the cabinet door the tv is mounted to. Its located behind it on the inside of the cabinet.
tmhyer is offline   Reply With Quote
Old 05-05-2014, 06:13 PM   #9
wesslvm's Avatar
No button on my 3050 Sunseeker.
2014 Sunseeker 3050S
Honda CRV (TOAD)
wesslvm is offline   Reply With Quote
Old 05-05-2014, 07:14 PM   #10
No button on my 2013 3051, at least that I've found. Occasionally my bedroom TV will find 1 or 2 less channels than my front TV, but I can rescan and it usually finds them.
cundie11 is offline   Reply With Quote
bed, roo
