Old 11-19-2014, 08:05 PM   #11
Not what you asked, and maybe you already know this, but the experience on a big RV forum is that you want your Ford Class C set to maximum caster. Which usually means they have to install some alignment shims or something to let it be set to that position. The caster number of 6 degrees sticks in my mind on this. Supposedly it makes a night and day difference.
2014 Sunseeker 2300 Chevy
Snowman9000 is offline   Reply With Quote
Old 11-20-2014, 08:36 AM   #12
trdutch's Avatar
Thanks for all the good info
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 11-23-2014, 08:25 AM   #13
http://www.funroads.com/coachcare/kenly/
Chas69 is offline   Reply With Quote
Old 11-28-2014, 06:19 PM   #14
Outlaw7's Avatar
Local Les Schwab Tire center did mine,,,much better driver now even if it wasn't all the way to special specs
Outlaw7 is offline   Reply With Quote
Old 12-16-2014, 04:00 PM   #15
Boso's Avatar
Sunseeker alignment specs
I have a 2015 Sunseeker 3050s that I need to have aligned.My question is are the specs I have seen posted not fords but the others have they been verified,should I worry Thanks Boso
Boso is offline   Reply With Quote
Old 12-16-2014, 04:06 PM   #16
GM
bclemens's Avatar
They are NOT Ford specs, they are much tighter than Ford specs. I am the one that posted them originally. Those specs were hashed out over 4 years with the help of one of our rental accounts that can put as many as 20k on a unit the first year. So we learned very quickly what worked and what didn't work.
Not sure why you would worry...many others on here have aligned to those same exact specs.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 12-16-2014, 05:36 PM   #17
Brian, a few posts indicated that FR may cover the alignment cost if done within the first 90 days. I'd like to take mine in to a local Goodyear truck shop to have it done, but it may be a bit outside of the 90d window since it has been in service at the dealer since October. Is there someone specific I should speak to at FR regarding this?
And thanks for your assistance on our 3050... Word from the dealer is we might actually be able to pick it up this week and take our first trip!
mattnlisa is offline   Reply With Quote
Old 12-17-2014, 07:32 PM   #18
GM
bclemens's Avatar
Here's the thing. The alignment specs that I post are much tighter than the Ford spec. Ford will typically cover an alignment to their specs...which are really broad.
There are no guaranties that we will cover the alignment to a more stringent spec (which requires the adjustable bushings).
Old 12-17-2014, 09:04 PM   #19
Mr. Clemens, I searched your old posts to find the specs you discuss above and could not find them amongst you most recent 500 posts. Could you point me to the actual post or repost so I can save them for later?
Gilm2113 is offline   Reply With Quote
Old 12-17-2014, 09:37 PM   #20
GM
bclemens's Avatar
If you search for "E450 Alignment specs" you get the following. I think it is about 11 threads down.
Forest River Forums - Search Results
alignment
