Old 10-28-2018, 06:26 PM   #1
Bus Driver
Deaver's Avatar
Front Overcab Clearance Light Cover(s)
Since this subject comes up from time to time for those of us that have an "older" Sunseeker or Forester, I thought I would pass this on.
The clearance lights were manufactured by a company called Glo-Brite who is no longer in business. Few parts suppliers have parts by now but, every once in a while they appear. They look like THIS
Yellow Lense - Click HERE
They may be pricey but available.
I carefully removed each lens and inspected it for cracks and replaced as necessary. Because it takes an almost acrobatic skill to deal with these lights, I decided to "modify" them as follows
I purchase these LED's Click HERE
You want to use this style as it uses a miniature PC Board for the contacts. Don't use the plastic base types as they will not last due to heat (I know)
Before inserting the LED assembly, put a smear of Permatex dielectric grease on the board portion to keep corrosion in check
Apply a small bead of RTV silicon adhesive on the inside edge of the lens before reapplying. This will keep water intrusion to a minimum.
I completed this mod three to four years ago with no issues
2012 Forest River Forester 25651S - The Magic Bus
Just trying to be the person my Dog thinks I am
Deaver is offline   Reply With Quote
Old 11-02-2018, 04:30 PM   #2
Thanks. I found the rectangular rear ones on Amazon. Luckily my oval front ones are still OK, but worth knowing regardless.
Steve
2013 Sunseeker 2650
2015 Jeep Wrangler
stevemoores is offline   Reply With Quote
cover, light
