Old 07-31-2016, 02:13 PM   #11
Fuel mileage ford v 10. My 2005 Lexington 26' gets almost every time out 11.5 mpg. There are many factors which affect fuel burn, the box over the cab on class c's is a big factor, along with speed , wind altitude and hills etc. my experience has been 62 mph is the best speed for combining rpm, time to get there traffic etc. last summer's 2000 mile to Yellowstone Salt Lake City and back to Ca. By the way travel at 4 to 5 thousand feet altitude, with a good tail wind on this trip, 15 mpg. Your aerodynamics, weight speed, and elevation will bring the mileage down, but much below 9 seems excessive. Lexidriver.
lexdriver is offline   Reply With Quote
Old 07-31-2016, 05:01 PM   #12
grumpy0374's Avatar
Boy, you must be doing something right!!! At 62 mph I couldn't get my Lexi to give 11.5 mpg, going downhill with a 40 mph wind blowing behind me. And that's running totally empty. Best my ScanGuage ever showed me was around 8.5, running on flat interstate at 65 mph, without my toad. Loaded for a trip, with my toad, anywhere between 6.5 and 8 mpg, is average.
Are you getting your figures from the gallons to miles or from a Scanguage?
Grumpy
Steve & Cheryl + Charlie & Casey, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
Camping trips this year so far...8
Days camping...75
grumpy0374 is offline   Reply With Quote
Old 07-31-2016, 05:08 PM   #13
Retired JSO's Avatar
Originally Posted by grumpy0374 View Post
If your using the old method of dividing the miles traveled by the # of gallons you pumped it is NOT an accurate measure. Things like heat, humidity, a slight incline at the pumps will all have an effect on the # of gallons you put into the tank. Just a difference of 1-2 gallons can throw your calculations out the window.
Only accurate way to keep track of mpg is to get a Scan Guage. It's hooked directly to the OBD port, and gets it's info directly from the computer. It will give you the mpg per tank, and also keep a running average over a period of time/miles. And, it's accurate.
Same guage will also keep track of engine temps, speed (mph). You will find that your speedo is off by as much as 3-5 mph when compared to the Scan Guage.
As for your mileage that you posted...it's actually in the "good" range for a V-10 class c.
As for me, I don't care a whit what my mileage is. We bought the rig to have fun, and experience the USA and what's out there.
Grumpy
He has a 2016 ford, it will give gallons used on the dash. If his is like mine, it's pretty close to hand calculations.
Retired JSO is offline   Reply With Quote
Old 07-31-2016, 05:14 PM   #14
ilmor's Avatar
I'm sure the Lexi aero makes a big difference, not to mention its size and weight. There are pros and cons to every model.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 07-31-2016, 06:20 PM   #15
I also have 2700DS. 8-9 mpg going 62-63
Full Stringer is offline   Reply With Quote
Old 07-31-2016, 06:28 PM   #16
ilmor's Avatar
Oh cool another MPG thread!!
Old 07-31-2016, 07:02 PM   #17
Are you running the 450 or 350 ?? If it is a 350 it has a different diff so that sounds right
Wayne
knoddy is offline   Reply With Quote
Old 07-31-2016, 07:04 PM   #18
Old 07-31-2016, 10:00 PM   #19
Wandering's Avatar
Knoddy
I'm averaging just under 8MPG running 65-70 in my 27' Forester. 6.5 MPG when pulling my Mini Cooper toad.
I'm a geek so track mileage with every tank and use the UltraGauge.
Forester 2451s
Forester 2451s
Wandering is offline   Reply With Quote
Old 07-31-2016, 10:02 PM   #20
Thanks for the reply.
