Old 05-18-2014, 05:07 PM   #1
Jmsx2's Avatar
Furnace - AC Question
Hi Everyone..
This may seem dumb, but to me it doesn't make sense. We used our Sunseeker 3050S for the second time since we took delivery this past weekend. I turned the furnace on becuase it dropped down to 39 degree in NW PA.
When I turned the furnace on the AC Unit kicked on as well and started moving some air. The furnace is working and blowing heat out of its ducts, but the AC Ducts is also blowing air, almost like it's in fan mode.
Keep in mind that our Coach has the Heat Pump Option as well. However I had the Thermostat in the Furnace Mode, not the Heat Pump Mode.
Is this a normal function of the furnace for the AC Unit to kick on as well? In our TT, when I turn the Thermostat to Furnace Mode, just the furnace comes on (then again, our TT does not have a Heat Pump).
If this should not be happening, what may be causing both units to kick on?
Thanks everyone.
John & Janine
Pazzo (Maltese)
New Brighton, PA.
2018 Coachmen Chaparral 338 TSIK
2016 (Seasonal Site) Chariot Park Model
2015 Chevrolet Silverado 2500HD
Jmsx2 is offline   Reply With Quote
Old 05-18-2014, 05:24 PM   #2
fonzie's Avatar
Set your thermostat to "auto" instead of high/low and it should do it.
Look at page 9
Fonzie
Old 05-18-2014, 05:26 PM   #3
fonzie's Avatar
Set your thermostat to "auto" instead of high/low speed.
Look at page 9
Fonzie
Old 05-18-2014, 05:38 PM   #4
Jmsx2's Avatar
Look at page 9
Thanks.. I went through every piece of paper that came with our Coach.. Wouldn't you know it, we do not have one on the AC Unit and Thermostat. Go Figure.
We'll do that next trip out....
John & Janine
Pazzo (Maltese)
New Brighton, PA.
Old 05-18-2014, 05:40 PM   #5
Jmsx2's Avatar
Look at page 9
Sweet.. That's a great help.... I'll download that and print it off.
Thanks again....
John & Janine
Pazzo (Maltese)
New Brighton, PA.
furnace
