Old 05-16-2015, 09:22 PM   #1
Gap when couch removed?
Removed couch in Sunseeker. The slide is elevated about 6 inches. We'll be using a recliner (s) Any suggestions on how to cover the gap? Pictures attached
ID:	77164   Click image for larger version
rlchall is offline   Reply With Quote
Old 05-17-2015, 12:26 PM   #2
widogmom's Avatar
You could make a skirt out of fabric to coordinate with your recliners. If you used lighter fabric you could shirr it, or pleat heavier fabric. Attach with velcro so you can remove for washing or drycleaning (depending on fabric). If you used lightweight fabric you could even use "no-sew" hem tape, but if you go this route be careful with laundering. A skirt will also help keep dust, debris, and (if applicable) pet hair out from underneath.
2015 Sunseeker 3010DS
2005 Honda Element (toad)
Now, Voyager, sail thou forth, to seek and find.
widogmom is offline   Reply With Quote
Old 05-17-2015, 01:06 PM   #3
Ours has a rubber flexable seal that's scewed to the front of that lip. Wonder what happened to yours? It doesn't look the best, but gets the job done.
2011 Sunseeker 3170DS - 30,000 miles explored
funfinder5 is offline   Reply With Quote
Old 05-17-2015, 02:13 PM   #4
Ours is a 2007 Sunseeker. We just had the couch removed, so maybe it didn't have a rubber flexible seal???? Widogmom, I'm thinking velcro and material might work. If not, it won't cost an arm and a leg to change it again. It won't drag to mess up the motor. Thanks for the tips yal. Others? Pictures?
Old 05-18-2015, 01:41 PM   #5
I like the velcro / material option. If you're looking for something flexible, yet sturdy, maybe try "pleather" as your material. It would hand straight down & be weather/water resistant. A less flexible option may be Peel/Stick floor tiles to match your floor - Attached with velcro, or more permanently (tacks/staples/screws)?
Joe & Sue - Camp Mutt Dazey
2008 Flagstaff Super Lite 26RKS
2008 Ford F-150
hotzfamily is offline   Reply With Quote
Old 05-18-2015, 07:19 PM   #6
I like the pleather idea especially for cleanliness and texture for hanging.
Thank you all.
Old 05-19-2015, 08:12 AM   #7
Frank & Eve's Avatar
We did the same with the skirt idea when we put in our reclining loveseat to cover the rubber flap. Used hot glue.
Frank & Eve is offline   Reply With Quote
Old 05-19-2015, 08:47 AM   #8
jaxfl's Avatar
rlchall and the others that have changed it out....
What recliners did you get, Lazyboy, or FlexSteel or what?
jaxfl is offline   Reply With Quote
Old 05-19-2015, 09:02 AM   #9
bb920's Avatar
I made a skirt out of some old carpet I had, it matched the carpet in the bedroom side. It's EZ to push out of the way when sweeping up.
Bill & Kay
Green Bay, WI
2016 FR Berkshire 38A
bb920 is offline   Reply With Quote
Old 05-19-2015, 02:04 PM   #10
Does
Can anyone share a picture?
