Old 03-04-2013, 07:23 PM   #1
Hoglou's Avatar
Gen auto transfer switch
Question 2... How does the gen auto transfer switch work? Leaving the shore power connected (hot) is ok when you exercise the genset?
Hoglou westGA
KM4HQQ 146.640mhz
Old 03-04-2013, 07:29 PM   #2
Denver, CO
garbonz's Avatar
On auto the gen won't get much exercise unless you unplug the AC cord.
2017 Fuse 23T
Old 03-04-2013, 07:31 PM   #3
TURBS's Avatar
Auto switch will default to shore power first .
TURBS
Old 03-04-2013, 07:35 PM   #4
VinceU's Avatar
Yes thats fine, the auto swith priority is shore power is 1st available supply, gen set will energize but will not accept load untill the shore power is removed (electrically, unplugging is not necessary). The switch coil inside the xfer switch is energize by shore power, therefore whenever its available it will be the supply. Defaults to Gen set on loss of shorepower.
Old 03-04-2013, 08:49 PM   #5
When exercising the generator, it should be run with at least a 50% load on it. Therefore, you need to disconnect shore power so that the generator takes the load. Run something that puts load on it. I have the AC with heat pump, so I run the heat to exercise the generator.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 03-05-2013, 07:41 AM   #6
Hoglou's Avatar
thanks to all..
Good info.. Keep teaching.. Don't want to destroy the coach, would rather wear it out.. Any major "don't do that" messages?
Hoglou westGA
KM4HQQ 146.640mhz
Old 03-05-2013, 08:26 AM   #7
CLASS "A" Senior Member
cfsoistman's Avatar
Don't forget to plug your coach back in after exercising the generator. My personal favorite is Don't forget you're exercising the generator. Forgot mine once and left it running for about 5 hours., I was painting a room, finished, cleaned up, started watching TV, fell asleep and hours later when my Daughter came home she asked if I knew the generator was running on the motorhome?
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 03-10-2013, 11:10 AM   #8
I have a Lexington 255 and a generator problem, the generator runs find but does not provide power to the coach. I just replaced both batteries as they were bad, since replacing them I haven't had any power to the coach from the generator. I have power to the coach with shore power. Any help would be most appreciated.
flyboy90 is offline   Reply With Quote
Old 03-10-2013, 11:21 AM   #9
Plain Old Member
flyboy90, sounds like a definite transfer switch problem. Pretty easy to replace one.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 03-11-2013, 09:32 AM   #10
Could you possible tell me where that switch might be located on an Onan generator. Also could the switch be purchased locally or do I need to order a replacement from Onan? I have never had any trouble with anything like this in all my years of RVing, sort of feel like a newby right now. I sure appreciate your fast come back and info just need more. If possible I sure would appreciate any further help you could provide. Thanks again, John
