Old 08-14-2014, 08:54 PM   #11
No idea about what? Replies seem to have crossed.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
Old 08-14-2014, 08:55 PM   #12
TURBS's Avatar
Looks like 4000 watts running.
FYI
Typical power output change based on ambient conditions:
- Temperature: Power output decreases 1% for every 10 F (5.5 C) increase
- Altitude: Power output decreases 3.5% for every 1000 ft (305 m) increase
TURBS
"SABRE OWNERS UNITED"
Old 08-14-2014, 09:03 PM   #13
Adding to Turbs standard temperature is about 60 degrees F. At 100 F would loose 4% and if at 5000 ft also loose another 18%. If loaded at sea level could be over at this condition.
I think like Turbs the TV's and other loads are just too much with microwave and water heater and/or A/C. Start with A/C only and add other loads.
RamblerGuy
2011 Sunseeker 3100
Old 08-14-2014, 09:05 PM   #14
I am on the coast. 0 altitude. I have everything off, including fridge. When the compressor kicks on the generator dies. I verified the altimeter setting. It is on zero.
Thanks for all you help guys. I guess I may just have to take it in.
Jlklingejr is offline   Reply With Quote
Old 08-14-2014, 09:05 PM   #15
TURBS's Avatar
The a/c and microwave alone are quite possibly 28 amps.
TURBS
Old 08-14-2014, 09:23 PM   #16
TURBS's Avatar
with all due respect I don't think the generator has a problem.
I think you're just overloading it.
TURBS
Old 08-14-2014, 09:26 PM   #17
There have been some bad fuel pumps. That may be your problem.
RamblerGuy
2011 Sunseeker 3100
Old 08-14-2014, 09:28 PM   #18
that generator should trip the breaker long before it dies due to overload. I would be looking at the fuel system. The onans have had a history of bad fuel pumps.
lbrunning is offline   Reply With Quote
Old 08-14-2014, 09:36 PM   #19
Depends on the load. I've had generator stall before breaker tripped when AC started. Was so fast breaker did not have time to respond. If AC was already running and say water heater came on which has little inrush load above normal amps breaker may trip first.
RamblerGuy
2011 Sunseeker 3100
Old 08-14-2014, 09:44 PM   #20
wesslvm's Avatar
I have same generator, runs everything no problems. I did have a bad fuel pump with less than 5 hours run time, in my case it wouldn't start.
2014 Sunseeker 3050S
Honda CRV (TOAD)
wesslvm is offline   Reply With Quote
air conditioner, generator
