Old 08-14-2014, 09:50 PM   #21
If its the load killing the generator before the breaker trips something is wrong with that engine.
lbrunning is offline   Reply With Quote
Old 08-14-2014, 11:16 PM   #22
So normally when you overload a generator the circuit breaker trips without the generator shutting off?
Jlklingejr is offline   Reply With Quote
Old 08-15-2014, 04:55 AM   #23
AquaMan's Avatar
Does the generator have any type of "eco" setting? Not sure on built-in generators, but on my portable, it will run my A/C on full power, but not on eco. If I gradually load up the generator, it will run most everything just fine. It just won't take that first inital draw from the A/C all at once.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 08-15-2014, 05:44 AM   #24
I disagree. The starting load of the A/C is instantaneous and is several amps more than the running load. Breakers take a little time to trip out. They have to be this way to permit starting loads. The generator doesn't have the excess capacity that a shore line can supply so starting loads affect it more.
Old 08-15-2014, 06:06 AM   #25
No the onan generator does not have an eco setting. For what it is worth here is how I run my sunseeker refrigerator on auto water heater on propane and ac on most of the time never had a problem with generator stopping or breaker tripping. I can run ac and microwave or hot plate or hair dryer and not trip breaker. I currently have 1027 hours on my generator trouble free. A couple other things to check is your fuel tank over 1/4 full and did you check oil level in generator .
Old 08-15-2014, 09:17 AM   #26
GM
bclemens's Avatar
What size is the A/C??? 13.5 or 15k with heat pump?
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 08-16-2014, 12:33 PM   #27
I don't know if there could be any special safeties on the Onan that doesn't like the wiring for your A/C?
I'm saying, *maybe* there is a wiring fault to your A/C that the shore power just doesn't worry about but the generator is sensing a problem and killing itself as a precaution.... IF this is even possible.
I have on one occasion had the Onan to shutdown as soon as we turned the A/C on but, I just restarted it and tried it again without any issue.
Mine was just a cold engine issue.
Again, *If* there are any safeties built into these generators then I would suspect that.
howzball is offline   Reply With Quote
Old 08-16-2014, 02:46 PM   #28
My A/C unit is a 13.5.
Old 08-17-2014, 05:24 PM   #29
I let my generator run for an hour with no load. Then I turned on the A/C and the A/C started right up. I am going to let it run for a couple of hours. Should I do this every time or should I take it in on warranty? I used to be able to start the A/C right away with no issues. Also I am at my 20 hour first oil change so am going to change the oil after it runs for 2 hours on the A/C.
Old 08-17-2014, 05:41 PM   #30
Average Joe
MrJoe's Avatar
I've tripped the generator breaker a couple times. I keep forgetting the electric water heater is on when starting the microwave with my 15K Ac/Heat pump running. Never had the generator stop. Does the panel flash a code?
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
air conditioner, generator
