Old 09-03-2014, 07:49 AM   #1
Generator problems
Onan 4kw
22 hours
anyone have similar problems?
Unit will start and run for 4-6 minutes and die. With no load.
Oil level is full ,
full tank of gas.
Is there and inline fuel filter somewhere?
It is in a 2014 sunseeker 3010dsf
Kevin & Judy is offline   Reply With Quote
Old 09-03-2014, 11:57 AM   #2
Did you get an onan book in your manual packet if so it tells you how to find the fault codes then tells you the possible problems related to the fault code.
lbrunning is offline   Reply With Quote
Old 09-03-2014, 12:08 PM   #3
No fault codes
I Have an appointment at Onan on Friday. I will update on what they find.
Old 09-03-2014, 04:01 PM   #4
GM
bclemens's Avatar
Onan had lots of problems with fuel pumps this past year.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 09-03-2014, 06:24 PM   #5
Just dropped it off at Cummins/Onan and that is what the service writer figured it is, Thanks for the feedback.
Old 09-03-2014, 08:28 PM   #6
Campin Cajun's Avatar
Check the air filter.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 09-04-2014, 09:10 AM   #7
Filter like new.
Old 09-04-2014, 09:42 AM   #8
Likely a fuel pump issue. Many people have posted failures here some of them multiple times as replacements were also defective. Some people carry a spare with them as new pumps may not be readily available on the road.
ATVer is offline   Reply With Quote
Old 09-07-2014, 11:52 AM   #9
Yes it was the fuel pump. Took it into Onan and they replaced the pump assy. Dropped it off on Wednesday evening and it was ready Thursday at 10;30 am, I was surprised how quick it was,
No have to get it in for the power converter not working, quit charging the batteries,
When it rains it pours, Charges from the alternator but not on shore power any longer, checked all fuses and the reset all were fine.
Old 09-07-2014, 12:08 PM   #10
Ford Idaho's Avatar
Take it back to Onan and have them double check their work, sounds like they did not hook up a wire or three.
generator
