Old 04-22-2018, 03:34 PM   #1
Hoglou's Avatar
Good bye wheel simulators
Using TPMS with the wheel simulators for me was a pain. Fixed the rim scares (white primer was great match) and swapped to center caps.
Happy days..
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 04-22-2018, 04:27 PM   #2
RedLdr1's Avatar
Looks really good!
Now if I can find nice center caps to fit a E-450 dually I'll join you in ditching the "wheel simulators"....
Wayne and Christine
2019 R-Pod RP-180 10th Anniversary Edition
2018 Ford F-150 SuperCrew Lariat FX4 (4X4) 3.0L Power Stroke Diesel
RedLdr1 is offline   Reply With Quote
Old 04-22-2018, 04:27 PM   #3
I like that !
2020 Rockwood Mini Lite 2509s
2019 F-150 3.5 EB SCREW Max Tow - 1797 payload
s1njin is offline   Reply With Quote
Old 04-22-2018, 04:39 PM   #4
Now a "Top Member"
EdJunior's Avatar
Okay, I'll bite. (Because I don't know) What are wheel simulators?
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - Still too new
Old 04-22-2018, 04:41 PM   #5
Hub caps?
2018 Silverado 3500 Duramax DRW
2019 Grand Design Reflection 312BHTS
Brewhedd is offline   Reply With Quote
Old 04-23-2018, 07:56 AM   #6
RedLdr1's Avatar
Originally Posted by Brewhedd View Post
Hub caps?
Over priced, over sized, over weight, full wheel "hub caps" that FR installs on most motor homes... They rattle, they block the valve stems, and the even come off and pass you occasionally... True junk...
See the attachment below.
Wayne and Christine
Old 04-23-2018, 10:24 AM   #7
Total Loss's Avatar
I did something similar but went one step further.
Blacked out the wheels to match the black trim on the rig and added trim rings.
Ease of tire pressure adjustments is great now.
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
Old 04-23-2018, 12:01 PM   #8
Also used on Jayco and Winnies.
Old 04-23-2018, 01:28 PM   #9
Hoglou's Avatar
mash - adam's ribs
Trim rings, dang that would have saved me a lot scar fixen's. Reminds me of Hawkeye ordering ribs and forgette'n the cole slaw. Part number and source?
The centers are from hubcap heaven $170 delv.
C5125FS-CHEV Chevrolet 3500, 4500 DRW Front Silver OEM Center Cap #15053704
C5125RS-CHEV Chevrolet 3500, 4500 DRW Rear Silver OEM Center Cap #15053705
All the grey is brushed primer to fill in the scars. Sanded with 150, 220, then wet 500. Hay, it's what I had in the shop..
.. If you are ordering a new coach ask them to leave the wheel simulators inside the coach, you can then decide if you want'em. Do you want'em I got four to ship....
ID:	169333   Click image for larger version
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Old 04-23-2018, 02:06 PM   #10
Good Bye Wheel Simulators
Hoglou, I ditched the simulators also. I assume you have duallys on the back axle. What air compressor brand, and where purchased, do you use to get the air hose on the valve stems that face toward the wheels? Very difficult to get air hose through the rim holes and onto the stems. Local tire dealer advised not to use valve stem extenders as they will break off from the rim. Most air hoses I've looked at are too stiff to get on the valve stem; they are not flexible or long enough to attach. Also what brand of TPMS (where purchased) are you using? I have a 2018 Coachmen Freelander Chevy 4500. Thanks Pat
thepeddler is offline   Reply With Quote
wheel
