Old 04-13-2016, 09:28 PM   #11
Just got a Sunseeker 2450S and I am trying to figure out the Magadyne system. What little I can figure it has GPS but it doesn't activate. Any clues. BTW....Absolutely NO paperwork came with the vehicle.
Pasha26287 is offline   Reply With Quote
Old 04-13-2016, 10:41 PM   #12
Google magadyne and download the manual.
rekwiat is offline   Reply With Quote
Old 04-14-2016, 04:15 AM   #13
You may also have a dodgy sd-card. Phone Magnadyne and find out. One of the signs is that it does not go through the start - up procedure. Basically it hangs.
flying_dutchman is offline   Reply With Quote
Old 04-15-2016, 09:24 PM   #14
Garrette's Avatar
I have a Magnadyne and all I can say is, buy a Garmin, stick it to the windshield and be happy. IMHO.
Garrette is offline   Reply With Quote
Old 04-25-2016, 04:55 PM   #15
While we are on the Magnadyne subject, I have a question. Does the radio need to be on for the GPS to give voice directions?
PenJoe is online now   Reply With Quote
Old 04-26-2016, 04:40 AM   #16
There is no need to have the radio on.
When you switch on the radio will always work but what I do is switch on BT (blue tooth) Radio will be off and then you can switch to GPS or when it is already running push the button on left above the screen to switch to the GPS. In set up you can adjust the volume and also arrange that the volume increases when you drive faster (more noise) If you want to switch off I always use the remote control because the gps does not need to go through the full start up procedure but starts immediately.
I hope this solves your problem.
2014, sunseeker
