Did you check your plug ends and female socket on your rig? Could be debris, excessive oxidation or moisture causing a short, or just creating too much resistance. If everything in your rig is turned off then it shouldn't be pulling any more than just static juice along the line. Any cracks along the cord?
Lastly, what else is on that 15amp circuit, and are you sure your water heaters electric is off? Hope it's not empty and still on or it's probably the twisted remains of your electric element shorting.
