Old 11-10-2010, 02:28 PM   #1
ground wire on 2004 sunseeker (rv body)??
need help in locating
Jim M is offline   Reply With Quote
Old 11-10-2010, 06:23 PM   #2
Grounding wire run to frame under the panel, but if you looking for the shore power ground it goes to your panel, where all other ground wire come to the same ground buss .
2010 wildcat 31ts
05 Ford F350 SD PS
camprat is offline   Reply With Quote
Old 11-13-2010, 10:58 AM   #3
Shore power works. Inside power works.
RV - body outside lights (e.g.-tail lights, turn signals & brake lights).
When applying the brakes or turn signals - odometer light flashes also. I took tail light lens off and grounded tail light to receiver hitch - everything worked properly. My question is where would I find ground strap to the right spot.
Old 11-13-2010, 11:04 AM   #4
Could it be that you 7-pin connector isn't isn't grounded to the tow vehicle? If so just run a ground wire from 7-pin receptive on your pickup to the frame.
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
sunseeker le
