Old 05-24-2014, 10:58 AM   #1
Had my first experience with Pex this weekend.
This is the first weekend we've had the Coach out this year because of my son's wedding.
So I dewinterized the Coach yesterday and found a leaky valve on the cold water going to the hot water tank. So I went to an RV store which had nothing and ended up at Home Depot in a panic.
Well Home Depot had everything except advice on how to remove those nasty little metal clamps. Finally I gave up and looked at Home Depots website and walla they had a video. After farting around for nearly 5 hours, I had the material and wherewithal to repair it. It wasn't pretty but I got it right for this weekend and I will redo the repair this week so it looks good.
I was just off about a half inch in length.
So I recommend everyone get familiar with how to do that repair!! And carry some Pex.!
MikeRP is offline   Reply With Quote
Old 05-24-2014, 11:11 AM   #2
Who Dares, Wins
doc73's Avatar
Good job. I will need to watch thid video myself. Never know when it will be needed.
Sent from my SAMSUNG-SGH-I747 using Forest River Forums mobile app
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 05-24-2014, 12:02 PM   #3
Did you rent or buy the Pex crimp tool? or did you use (Shark Bite)? Youroo!!
Old 05-24-2014, 01:10 PM   #4
Lynkage's Avatar
This is a kit that just stays in the camper.
The crimper was $40 at Lowes/Home Depot and works on all sizes of PEX cinch clamps.
I highly recommend everyone has one of these setups so that you can repair leaks on the go without having others come to fix it for you.
PEX is also very forgiving and fittings can be re-used if brass and sometimes you can salvage the plastic ones as well. I prefer to use the Brass fittings as I know they can take some abuse especially it the cold weather.
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 05-24-2014, 01:43 PM   #5
Where did you get that kit, or was it just made up by you.
Old 05-24-2014, 03:50 PM   #6
Yes I bought the sharkbite crimp tool and some blue Pex and some metal crimpers.
I think maybe I should buy an assortment of valves and fittings also to carry along.
Old 05-24-2014, 03:51 PM   #7
Id love to have that kit!!!!
Old 05-24-2014, 03:51 PM   #8
Is sharkbite bad?
Old 05-24-2014, 04:07 PM   #9
Professional Texan
TexasBob's Avatar
Is sharkbite bad?
Sharkbite fittings are great. I've used it for repairs at home. Some have said that sharkbite connectors might not do well in in an RV environment with the down the road vibration. I kind of agree. Except in emergencies I would use a crimp fitting on my RV.
Texas Bob
2015 Chevrolet Silverado HD2500 Z71
2013 Prime Time Tracer Executive 2640 RLS
TexasBob is offline   Reply With Quote
Old 05-24-2014, 06:58 PM   #10
This is ,(Sharkbite fitting) require (NO) crimp tool,or metal crimpers! There are PEX sleeves that require crimping with a tool,but (Sharkbite ) push into the (Sharkbite) fitting! At the most the only tool needed for (Sharkbite) is a PEX hose cutoff tool! Youroo!!
