Old 12-03-2015, 08:41 PM   #1
Ham rAdio in 3050s
Looking to install a dual bander in a 3050s 2013. looking for the best place to put an antenna and any problems with the power output. H R O said we should check with factory for any problems with placement and power outup of unit. I would think that ford would be the contact, and not forest river as the cab is ford. Someone must have put a radio in a unit already please reply back n1wnr keep on camping
oldnewguy is offline   Reply With Quote
Old 12-04-2015, 08:26 PM   #2
Hoglou's Avatar
I am with ya. Running 2m handheld and would like to mount a proper antenna.
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 12-04-2015, 08:32 PM   #3
Campground host Mo. State
Photogirl's Avatar
Only advice is locate your antenna far enough away from tow vehicle onboard computer and any tuner/chip, It will cause tuner problems and transmit will lock on. W0FCG 73
Frank & Kathy & Daisy 2.0 Yorkie (Pack leader)
2008 Ram 6.7 Diesel, 4.10 diff., EGR valve delete, MBRP straight exhaust, Mini Max race tuner, K&N
2016 Crusader 321 RES Ham call W0FCG
Days camped in 2015- 111 in 2016-75 in2017-61
Photogirl is offline   Reply With Quote
Old 12-04-2015, 08:58 PM   #4
Forbes's Avatar
Unless you are running 50 plus watts I would not think you will have a problem. I have an Kenwood duel band in my F350 with antenna mounted at center rear of cab and have never had a problem. Aslo have Kenwood 930s with SB200 amp in RV using a Eagle One vertical antenna. WB4FSN
Roger & Mary Forbes
WB4FSN
Little Lady (Dog)
2014 F350 / 2015 CC 36 CKTS
Forbes is offline   Reply With Quote
Old 12-04-2015, 11:57 PM   #5
Photogirl's Avatar
Icom 2100H runs 55 watts on high.
Old 12-05-2015, 12:29 AM   #6
coupevillefish's Avatar
On my Georgetown, I put a "mirror" mount, dual band antenna on my luggage rack. Could have done the ladder. I can't remember right now if it is half or 3/8 wave but it doesn't stick up too much above the A/C. I ran about 30' of coax and found a path into the cabin. I have only used while parked with my Yaesu FT2900 but it would work with my HT. I rarely go more than 5 watts.
coupevillefish is offline   Reply With Quote
Old 12-05-2015, 07:38 AM   #7
Forbes's Avatar
Should not be a problem,
Roger & Mary Forbes
WB4FSN
Little Lady (Dog)
Old 12-05-2015, 04:37 PM   #8
I mount a Cushcraft AR270 dual band on a pole and attach the pole to the ladder. Is a half wave antenna (do not need a ground plane). Takes a few minutes to install once situated at the campsite.
2017 Berkshire XL 40A & 2017 Ford Focus SE
I Built and Fly - Van's Aircraft RV-12
Ham Radio - W9EAA
MartyQ is offline   Reply With Quote
Old 12-05-2015, 05:50 PM   #9
JnScattle's Avatar
Forbes, could you share a pic of your Kenwood mounted in the RV; interested to see location and how mounted. Thanks...//jmc
______________________________
J & S
Traveling the world with Uncle Sam!
2014 2500HD Duramax Crew 4WD
2015 Forest River Salem 30QBSS
JnScattle is offline   Reply With Quote
Old 12-06-2015, 01:25 PM   #10
tomfmcs's Avatar
You could mount these diamond mounts near the front of the hood just inboard of head lights. These mounts adjust on three axis's. Unscrew antennas when you open the hood. Short cable runs also. I'd put ferrite chokes at each end.
tomfmcs is offline   Reply With Quote
305, 3050s, radio
