Old 01-25-2015, 08:43 PM   #1
HDMI wiring
Just spent some quality time with John Pagano at the Ft. Myers show. He told me that the new sunseekers were coming thru with hdmi wiring as standard. I was interested in the 2800 gts model but when we looked, we were unable to confirm that that model also had hdmi. He suggested that I post this question on the forum and that Brian may have an answer.
Monarch is offline   Reply With Quote
Old 01-26-2015, 06:41 AM   #2
HDMI wiring? HDMI is for connecting audio/video devices. I'm a bit puzzled as to what HDMI wiring is.
biznsa is offline   Reply With Quote
Old 01-26-2015, 07:35 AM   #3
Phat Phrog Stunt Crew
elind's Avatar
Could this be used to connect a second TV to a Dish satellite receiver so you could have an option of which TV to watch?
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 01-26-2015, 08:29 AM   #4
I suppose that could be the case. In that case, I would think it would be an additional cable leading to the 2nd TV.
Old 01-26-2015, 09:12 AM   #5
hammer55's Avatar
plc connect
the only reason I would want it is if I want to connect my computer to the tv, to watch netflix or fox news, if it does not have this option then I would later upgrade to a smart tv with wifi, the smaller tv's a getting cheaper these days, other than that not a big deal, do not the cable runs parallel through the coach, you could use those for communication also
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
hammer55 is offline   Reply With Quote
Old 01-26-2015, 09:14 AM   #6
Herk7769's Avatar
While Brian does scan the forum occasionally, I should remind everyone that he is a member here just like the rest of us and comes and goes as he has time.
If you need a quicker answer, a PM to him might be faster.
You might also try contacting Sunseeker directly.
FR does not own or support this forum. We exist solely as a result of income received from google ads. Thank you for supporting our advertisers.
HAM CALLSIGN - KC3FFW
Old 01-26-2015, 09:40 AM   #7
bubbles's Avatar
I wish my coach was prewired with HDMI cables so I could have HD SAT to my TV's. Have to settle for SD SAT using existing coax. Installing HDMI cables now would be a nightmare.
Old 01-26-2015, 04:54 PM   #8
GM
bclemens's Avatar
oooh, no PM's if possible. My inbox fills up faster than I can delete them.
I'm not sure what he meant by HDMI? IF you get the front entertainment center, we ARE wiring an HDMI plate to the wall of the cabinet. That way you don't need to take the TV down to add an HDMI connection to the TV (Blu-ray player, game, or HDMI connection from Sat).
As for the rest of the unit we do not have a good solution yet. To get over the air channels, we HAVE to run coax to every TV. There is no getting around that.
What we have talked about doing, is an HDMI switch box in addition to the coax. One in Four out. So theoretically you could have one HDMI connection that would feed the outside TV & bedroom TV.
But we are just in research stage at this time.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 01-26-2015, 04:55 PM   #9
GM
bclemens's Avatar
You do have direct access to the TV on the 2800. So there is HDMI input on there.
wiring
