Old 08-07-2015, 12:26 PM   #11
GM
bclemens's Avatar
Not brighter. As you load weight in the back, it makes the front point higher. Get a nice long screwdriver. There is an adjustment point in a hole,in the engine compartment. Should show how to do this in the owners manual.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 08-07-2015, 12:42 PM   #12
Originally Posted by Taranwanderer View Post
No such thing. Oncoming drivers have to deal with you for a few seconds. Yes, maybe you need to aim them lower. But you have to deal with lights that are too dim forever (like the ones on my Ram.). The brighter the better.
Yeah, I've encountered Drivers like you!! Too Many of them!!
One, last month on a Drive thru Wyoming, had the Balls to Constantly High-Beam me after I'd Flashed him thinking that he Already had the High-Beams On - Super-Bright HIDs so bright they generated their own Haze.
I was trying to Warn Him that there were Antelope along the Road - hiding in the Glare of his Lights. In my Rearview, I saw his Brakelights swerve in a Panic Stop. I was towing, so wasn't going to Back the 1/4 Mi unless Absolutely Necessary, but watched until he started to Drive On some 30-45sec later.
I wonder if he started to Rethink his Excessive Lights, or just Wiped Out his Drawers and Drove On...
Pup: '11 HW-296
TV: '09 RAM 1500 Hemi 4x4 CC
seigell is offline   Reply With Quote
Old 08-07-2015, 12:45 PM   #13
Originally Posted by rockfordroo View Post
For some reason, it seems to me that pickup trucks always seem to have brighter headlights. Since they're usually mounted higher, you would think they'd be aimed a bit lower to put the light at the same distance from the truck, but that doesn't seem to be the case. I haven't noticed this with MH's as much, but....
I agree with others that you probably need to aim them down a bit.
Semi Tractor Lights are becoming more of a Problem as the newest Aerodynamic Fenders actually Lower the mounting of their Headlights, requiring them to be aimed Higher in order to Illuminate to the Semi's Stopping Distance.
Pup: '11 HW-296
Old 08-07-2015, 01:12 PM   #14
Canadian Member
itat's Avatar
I had HID projectors retrofitted into my F150's headlight housings because The stock halogen bulbs were horribly dim. I have the projectors aimed so that the cutoff line is lower than the side mirrors of the car in front of me at an intersection. I never get drivers flashing at me. I tried HID bulbs in the stock housings but they created too much glare.
It's illegal, dangerous and extremely rude to have your headlights aimed too high. Please respect your fellow drivers and make sure to get them aimed properly.
It's easy to do it youself. Find out where the adjustment screw is and find a level area at the back of a Walmart facing the wall.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
light
