08-04-2015, 09:39 PM
Headlights too Bright?
Weird topic I know. We have a 2014 3170DS (ford) and every time I drive at night I get "flashed" the kind where they think your high beams are on. The last trip coming back from Florida we were in southern Illinois and a truck driver in front of me was so mad he swerved towards me as I was passing him, and trailed me for a couple of miles with his high beams on 15 feet from my rear bumper. I will admit they are bright. Has anyone else had issues?
08-04-2015, 09:41 PM
Towing ? Or just driving?
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
08-04-2015, 09:42 PM
Just driving
08-04-2015, 09:52 PM
could be that they are aimed a little high also so that the focal point is closer to the drivers eye level then the ground
2015 Cedar Creek Silverback 33IK
08-04-2015, 09:53 PM
I occasionally have the same issue not towing.
Semis are the worse for flashing me.
I simply flash them back.
TURBS
2011 32bhok Sabre
08-04-2015, 09:57 PM
Bus Driver
Assuming your High-Beams do work and you were using your Low-Beams, Do you have any air in your Airbags in the rear? Is the Rear higher than the Front? Are you lighting up the sky as opposed to the ground in front of you. Are they the OEM Bulbs and not higher wattage?
On my 2012 Forester, I've found my stock headlights to be marginal in brightness and pattern
Your Headlights can be "aimed" and can be checked by a Ford Dealer
2012 Forest River Forester 25651S - The Magic Bus
Just trying to be the person my Dog thinks I am
08-04-2015, 10:06 PM
I think you should have them adjusted soon. It is a hazard to other drivers. I travel every day in the dark going to work and there are a lot of head lights out of adjustment and it does blind a person. It's not hard to adjust them just pull up close to a wall of a building and lower them a tad.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
08-06-2015, 07:24 AM
I would check airbags and make sure you have the right pressure. The MH, when parked on level ground, should have a slight nose down attitude. If your front end is level with back, or higher, your headlights are pointing too far up. Also make sure tire pressures are correct. Placard on drivers door jamb indicates pressures. Mine is 65 front and 80 rear. Incorrect pressures can make the front end too high also. If all of that is OK, then adjust headlights. Should be information in owners manual (for chassis) about what is the correct height and how to adjust.
2012 Forest River Sunseeker 2300 Chevy
08-06-2015, 07:36 AM
No such thing. Oncoming drivers have to deal with you for a few seconds. Yes, maybe you need to aim them lower. But you have to deal with lights that are too dim forever (like the ones on my Ram.). The brighter the better.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (‘18)21 (‘19)23
2019 Honda CRV (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
08-06-2015, 07:59 AM
For some reason, it seems to me that pickup trucks always seem to have brighter headlights. Since they're usually mounted higher, you would think they'd be aimed a bit lower to put the light at the same distance from the truck, but that doesn't seem to be the case. I haven't noticed this with MH's as much, but....
I agree with others that you probably need to aim them down a bit.
2011 Traverse LT, 3.6L, FWD
08-07-2015, 12:26 PM
Commercial Member
Not brighter. As you load weight in the back, it makes the front point higher. Get a nice long screwdriver. There is an adjustment point in a hole,in the engine compartment. Should show how to do this in the owners manual.
08-07-2015, 12:42 PM
Yeah, I've encountered Drivers like you!! Too Many of them!!
One, last month on a Drive thru Wyoming, had the Balls to Constantly High-Beam me after I'd Flashed him thinking that he Already had the High-Beams On - Super-Bright HIDs so bright they generated their own Haze.
I was trying to Warn Him that there were Antelope along the Road - hiding in the Glare of his Lights. In my Rearview, I saw his Brakelights swerve in a Panic Stop. I was towing, so wasn't going to Back the 1/4 Mi unless Absolutely Necessary, but watched until he started to Drive On some 30-45sec later.
I wonder if he started to Rethink his Excessive Lights, or just Wiped Out his Drawers and Drove On...
Pup: '11 HW-296
TV: '09 RAM 1500 Hemi 4x4 CC
08-07-2015, 12:45 PM
Semi Tractor Lights are becoming more of a Problem as the newest Aerodynamic Fenders actually Lower the mounting of their Headlights, requiring them to be aimed Higher in order to Illuminate to the Semi's Stopping Distance.
Pup: '11 HW-296
08-07-2015, 01:12 PM
Canadian Member
I had HID projectors retrofitted into my F150's headlight housings because The stock halogen bulbs were horribly dim. I have the projectors aimed so that the cutoff line is lower than the side mirrors of the car in front of me at an intersection. I never get drivers flashing at me. I tried HID bulbs in the stock housings but they created too much glare.
It's illegal, dangerous and extremely rude to have your headlights aimed too high. Please respect your fellow drivers and make sure to get them aimed properly.
It's easy to do it youself. Find out where the adjustment screw is and find a level area at the back of a Walmart facing the wall.
