Old 09-23-2014, 08:24 AM   #1
Frankie Z's Avatar
Heat pump
Newbie question
I have a heat pump in my sunseeker
Is it all electric or is the heat run by propane?
Frankie Z is offline   Reply With Quote
Old 09-23-2014, 08:28 AM   #2
Papi
Papicamper's Avatar
If it's a "normal" heat pump it is your A/C unit running "backwards"...it uses electric power...the same as the A/C uses when cooling. Any help?
PapiCamper
Cedar Creek 36CKTS
F350 Lariat ("Big Blue")
Papicamper is offline   Reply With Quote
Old 09-23-2014, 08:28 AM   #3
Its all electric.
Kevin & Judy is offline   Reply With Quote
Old 09-23-2014, 08:47 AM   #4
You may also have a seperate propane furnace.
harderd is offline   Reply With Quote
Old 09-24-2014, 05:57 AM   #5
Heat pump
Heat pump uses 120 volt, so requires shore power or generator running. Furnace uses propane for heat and needs 12 volt for fan and controls. If you have shore power available and outside temperature is above about 30 F, the heat pump is a good alternative. If colder, or no shore power, then furnace.
Furnace has air ducts that blow heated air on water pump and sewer connections, and heated air also provides some heat around holding tanks, so consider using that when temps are near freezing.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
pump
