Old 06-24-2016, 09:16 PM   #1
BamaGrad's Avatar
Hellwig rear sway bar
Received my Hellwig rear sway bar today. Hope to install this weekend. Any insights or "gotchas" from folks that have done this? 2014 E450.
R & J
2015 Sunseeker 3170DS
2007 Ford Escape Toad-5 spd manual
Blue Ox Alpha tow bar/Blue Ox Patriot brake
BamaGrad is offline   Reply With Quote
Old 06-24-2016, 09:31 PM   #2
Want to install one also , where did you buy from and what part number did you order, please post your install , would like to here how hard/easy to install.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 06-24-2016, 09:33 PM   #3
SeaDog's Avatar
Haven't done that bar but have done the sway bar bushings on a 34' winnie. day before you start soak all the bolts and nuts with PB Blaster it will make the job much easier.
Retired Navy
2016 Flagstaff 26 FKWS
Old 06-24-2016, 09:36 PM   #4
BamaGrad's Avatar
Thanks SeaDog. Good Advise. Stang it is a Hellwig 7180 from Amazon ~$230. It appears to be a straight bolt-on replacement for my 2014. There are some videos on youtube for a slightly different model.
R & J
Old 06-25-2016, 01:09 PM   #5
Rockin M's Avatar
I will be interested in hearing your thoughts after you install the new bar and take it for a test drive.
Barry & Donna
2014 Forester 3011DS
2013 Chevy Equinox
Rockin M is offline   Reply With Quote
Old 06-29-2016, 08:36 PM   #6
Try to get someone to help you balance the bar for test fit. I used an air gun for quick removal of the old bar. I had to use a floor jack on the corners of the saddle brackets to lightly force them up while slowly tightening the bolts. The diameter of the washers supplied by helwig were too big; interfered with the shoulders of the saddle brackets. I used a creeper and the cardboard from the box to make it easier to move around under the rig. Use disposable gloves to apply the grease, it makes a mess.
mpincentralva is offline   Reply With Quote
Old 06-29-2016, 08:41 PM   #7
Installed front and rear helwigs on my 32 ft rig. Much less sway and rocking. Very pleased. See my reply to the OP about installation.
Old 06-29-2016, 10:01 PM   #8
BamaGrad's Avatar
Got it installed this weekend. MP is correct on needing additional assistance in getting the bar up and in place. I used a creep instead of a creeper :-) Close buddy and lots of beer.
I absolutely could not get it done by myself. It is a beast to hold up and install. The replacement bolts on the u-joints have short shoulders and end up being a little too tight. A thin wall socket works best.
The Hellwig instructions say to "press" into the hourglass rubber sleeve on the upper arm. It was more than a press for me. With everything greased, a hammer and 2x4 were needed then a 1/2 socket extension to get the sleeve nice and seated.
The front sway bar arrives on Thursday. We have 4000 mile trip coming up mid-July. Will report back on performance.
We did South Dakota and Yellowstone last summer. The winds through eastern CO and western KS made for two days of white knuckle driving.
R & J
sway
