If a mirror does not work, there are horoscopes which are not too expensive, compared to a worst case scenario repair.
If you cannot find and remove it already:
I would also take one of the other die's, and see if it crunches/breaks easy, say in a nut cracker. If it is relatively fragile, I would not personally spend a large amount of time looking for it.
If you have compressed air access, you can spray some air in to see if you can move things around. Or maybe a vacuum, duct tape, and some small flexible hose (one just enough to fit a die in, one smaller, to suction it to the hose end).
Maybe something flexible with a ball of reversed duct tape on the end.
