Old 12-05-2015, 09:30 PM   #11
You should open the pressure relief valve. That is located on the outside of unit behind metal door if there is water coming out, you can then flip the switch in the lower left corner and use the electric to heat the water. Don't flip switch on if there is no water or unsure of waterWish I had a pic to post, you can search water heaters on this forum and find tons of info and pics.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 20 nights
Miles traveled in 2017: 1,530
uhduh camping is offline   Reply With Quote
Old 12-06-2015, 08:36 AM   #12
sgtlm17's Avatar
Just a thought if your valves are correct and water comes out warm not hot check to make sure your outside shower is off at the knobs and not the actual shower head. Having outside shower knobs open will cause hot and cold water to mix when calling for hot water at another faucet
2016 Forester GTS 2801QSF
sgtlm17 is offline   Reply With Quote
Old 12-06-2015, 10:07 AM   #13
Cindimac's Avatar
Help help water heater
It worked...thanks boys..u all rock..especially Ford Idaho
Cindi Mac
Cindimac is offline   Reply With Quote
Old 12-06-2015, 02:45 PM   #14
jkoenig24
Do you have an outside shower / faucet? If those valves are left open, that can cause hot and cold water to mix which results in tepid water at the inside faucets.
jkoenig24 is offline   Reply With Quote
Old 12-06-2015, 03:08 PM   #15
7 Year Class A RV'er
Cindimac: Did you get it going? I had a different thought if it's still not working. You said you hear the gas ignite, go for a few seconds, the go out? If so, check the sail switch and make sure it's not stuck or blocked. Once the burner lights, the exhaust fan starts to blow. If the sail switch doesn't sense air exhausting through the flue it will shut off the gas flow for safety.
2015 Legacy SR340 360RB
Old 12-06-2015, 03:33 PM   #16
MNtraveler's Avatar
Originally Posted by Cindimac View Post
After winterizing our 2650 Sunseeker, we un-winterizing, read the manuals, we are now at a campground with full hook ups and the dang water heater doesn't seem to be heating the water, the water will come out warm for about 5-10 seconds then the water get luke warm. I've heard the gas light up, then shuts off. How long does it normally take to heat the tank?
Now I know we are newbies.. But what the heck.. I remember when we pick up the used 2012 that the water wasn't very warm brought it back to the RV place and he did something to get the water hot.. But I forgot what he did..must have had a senior moment.
Can any one have any suggestion, can't take a cold shower..
Cindi Mac
Glad to see you got it solved. However, if you have full hookups, you should be using electric water heater if possible rather than gas. You are already paying for the electricity and can save the gas for other uses.
MNtraveler is offline   Reply With Quote
Old 12-06-2015, 03:34 PM   #17
Ford Idaho's Avatar
Issue has been resolved.
Old 12-06-2015, 03:35 PM   #18
Also make sure outside shower valves are closed
Harkerr is offline   Reply With Quote
Old 12-06-2015, 07:34 PM   #19
Mr. Dan's Avatar
The issue has been solved. See above posts. Thanks.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
heater, water, water heater
