Old 04-09-2014, 10:13 AM   #1
Help Installing Brake controller on New 2014 E-450 Super Duty 2860DS
I could use some Help / Info on Installing Brake controller on New 2014 Ford E-450 Super Duty 2860DS. Has anyone had actual experience doing this on the 2014? I have seen where they say the prewired plug is in 3 or 4 different locations or non existent even. I've looked by emerg brake and don't see any open plug ins. some say behind little change dish on dash. just wondering how hard it is to get to behind the change dish. My wife will go nuts if I start removing stuff from dash. Any help , tricks, tips would be appreciated!
Also have been looking at Tekonsha 90195 Ps Electronic Brake control and 3034P pre wired cable. I will be towing up to high of max weight and as low as 1500#.. has anyone had experience with this setup on the E-450 and a Sunseeker?
Thanks for any help
Ron
asparky is online now   Reply With Quote
Old 04-09-2014, 10:53 AM   #2
GM
bclemens's Avatar
The brake controller harness is behind the little change/storage bin in the upper part of the dash. Just look at any picture of the Ford stock brake controller and you'll see that is where it is located.
You can sort of see it in this picture. Too small really...but right next to the change holder is the Ford brake controller. We have installed some for a rental dealer and we just put them right in the change holder, sticking out.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 04-09-2014, 11:46 AM   #3
Thanks BC, but don't see a picture
Ron
Old 04-09-2014, 02:52 PM   #4
fonzie's Avatar
Have a look at post #2, hope that it for you.
E450 trailer brake connector - iRV2 Forums
Fonzie
Old 04-09-2014, 03:45 PM   #5
GM
bclemens's Avatar
See, that's where all the confusion comes in. Different model years have different locations.
This is the picture I was trying to upload. As you can see (barely) where the coin holder was, there are some switches and the brake controller is to the left of that. I think normally the coin holder just gets smaller.
Old 04-09-2014, 09:02 PM   #6
Thanks for any help
Ron
The change compartment is a bit of a bugger to get out. Believe it or not, it is easier to push it out from behind - the trick is how to push from behind. I pulled my Magnadyne radio (pretty easy if you have to din tool that is supposed to be in the bag of "stuff"). Once the radio is removed you can reach around the vent duct and push on the box from there. You will see the brake control factory harness just kinda sitting there with the harness for the accessory switches (option adds).
You can even pop out the vent grills to give even more working room. The dash system in the Ford is among the easiest I've ever worked with.
Bobby
bgilly is offline   Reply With Quote
Old 04-09-2014, 09:45 PM   #7
OK Guys I couldn't get the coin holder out, and didn't want to break it.. It is a bugger!.. So I unsnapped the top of the dash from left to right looking at it and pulled it very slightly out just enough to look inside. I didn't even have to unsnap the right clip. and there was the red plug. I Reached in and pulled the plug out of the top of the dash. Then checked the 4 wires on the plug for correct voltages. Plugged a cable into it and fished it down and out of the bottom left corner of the console. Hopefully its ready to go, just got to get a controller and decide where to mount it... Any suggestions? On the controller and where to mount it?
Pretty easy after figuring out what's what!!
Thanks for all the Help
RON
Old 04-10-2014, 05:41 AM   #8
RON
I would try to modify the OEM compartment to get the Tekonsha Prodigy installed. Or you could hunt down a Ford OEM to properly fit.
I wouldn't below the dash - knee panel area. It's already fairly crowded down there and the isn't much of anything solid to mount it to.
Old 04-10-2014, 09:05 AM   #9
I mounted mine in the coin holder. cut a whole in the rear for the plug to go through.
2014 sunseeker 3170dsf V10
cruiserjohn is offline   Reply With Quote
Old 04-10-2014, 03:30 PM   #10
rbetzwieser's Avatar
I modified the coin holder and mounted mine inside it also. It keeps it within easy reach.
Sent from my SCH-I545 using Forest River Forums mobile app
rbetzwieser is offline   Reply With Quote
2014, brake control, controller, brakes
