Old 11-19-2015, 07:46 PM   #1
Reinita's Avatar
Help? Lights not coming on
Just picked up our Sunseeker 3070 from Campimg World after hours after some repairs and winterizig. None of the lights work inside the RV.
We checked the fuse box and everything looks in order.
We are not handy.
We are headed to a nearby state park for the night and hope that we can plug into power and have lights and the heat pump.
Any suggestions? Thanks!
Reinita is offline   Reply With Quote
Old 11-19-2015, 07:51 PM   #2
TURBS's Avatar
Is there a battery disconnect?
Old 11-19-2015, 07:55 PM   #3
RSchleder's Avatar
Is there a main "12V off" master switch somewhere?
Could they have depleted your coach batteries and they need charging?
Do you have lights with the generator running?
Do you have lights when plugged into the campground 110v?
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 11-19-2015, 07:56 PM   #4
RSchleder's Avatar
GREAT minds Turbs--you posted while I was writing mine.
30 years RV'ing
11 different RV's
Old 11-19-2015, 07:58 PM   #5
Bluepill's Avatar
Link to good overview of battery systems:
http://www.hrvc.com/console/files/Ba...0-%20Guide.pdf
See page 2 on Battery Disconnects
Old 11-19-2015, 09:03 PM   #6
When you open your coach door look to your left, there will be a large round switch marked on and off this is your battery cut off switch. everything should start working when you turn this to on. If you leave this switch on when not using your motor home things like your c02 detector, and tv sets will drain your coach batteries.
2016 Sunseeker 2700DS
2010 Jeep Liberty Toad
tlf65 is offline   Reply With Quote
Old 11-19-2015, 09:37 PM   #7
Reinita's Avatar
Aha!
We have lights! Came on when we plugged in and also found the knob.
Thank you all soooo much!
Old 11-20-2015, 01:49 PM   #8
Air Force Retiree
Post Main Battery Shutoff
Remember that main battery shutoff (Big Knob) must be in the on position to charge your house batteries when plugged in to AC.
Like quoted in above message, turn to off when not using the camper to stop drain on your batteries.
Retired Air Force is offline   Reply With Quote
light
