Old 07-25-2015, 01:02 PM   #11
I had the same problem with my MH. Turned out to be a faulty receptacle where the shore power plugged into.
poppoplou is offline   Reply With Quote
Old 07-26-2015, 07:41 AM   #12
Wolverine 1945's Avatar
Originally Posted by Yorkranchgalnguy View Post
Same problems a few weeks ago. Also suspected transfer switch because one side of it was dead, but it turned out to be the wiring in the wall after where the cord plugged in . A wire had not been tightened correctly at the factory - they also found a 12 v connection without a wire nut. So have your dealer check all electric under the bed, since it's a pita to get to!
That is scary stuff,,, could have been a fire !!!
Maybe workers need more time to do there jobs !!!
Wolverine 1945 is offline   Reply With Quote
Old 07-27-2015, 12:53 PM   #13
2012 FR Lexington 283TS
What is the charge state of your batteries??
Wig. What was the charge state of your batteries when the A/C refused to work? I have had a similar situation with my 283TS and I am currently replacing the factory WFCO unit with a Progressive Dynamics Inteli-power RV Converter PD9260. My A/C would not work on shore power unless the batteries had a charge. The RV dealer said that on of the batteries must have had a BAD cell but when I replaced the batteries, three days later it happened again. The WFCO charger was NOT keeping my batteries charged. I might have to replace the Transfer Switch. Kim
CaboSnow is offline   Reply With Quote
Old 07-31-2015, 04:14 PM   #14
This is the first really hot day since my last post on this thread. Same thing happened: the ac ran fine set at 78 this am . About 3 this pm I noticed it had gotten hot in rv. Looked at microwave: no 120v. Turned on genny, ac started right up! (Whew). Now what do I do? Call Dalton's, who found loose wire in wall where 120 plugs into coach, and supposedly fixed the problem? Could it be the transfer switch also? FR is going to reimburse $ for last repair, and we are squeeking under warranty again( ends in a few weeks). The frustrating saga continues. Any thoughts appreciated.
2014 Sunseeker
3170ds (Suzuki Samurai 1986 toad)
Gary and Dottie, fur babies Doodle(corgi) and Beau(yellow lab)
Yorkranchgalnguy is offline   Reply With Quote
Old 07-31-2015, 04:34 PM   #15
Boso's Avatar
Had similar thing happen on 50amp coach wire coming in was loose at the connection in bay cost me 50$ and 2 days camping because I didn't check connection
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 07-31-2015, 04:56 PM   #16
Found the problem: tripped breaker at the park's panel- not my rig! I should have checked the surge protector first. Thanks.
2014 Sunseeker
