Old 02-14-2016, 03:16 PM   #1
DoctorT68's Avatar
HELP ON ROAD: Side won't completely extend
Hi everyone
So I just pulled into Fort wilderness at Disney, and my slide won't go all the way out. I have no idea what to do. It sounds like the motor just stops when it is about 8 to 10 inches extended. Any ideas please?
Sunseeker 2016 3050SF
Bill
2016 SUNSEEKER 3050SF
The early bird gets the worm, but the second mouse gets the cheese
DoctorT68 is offline   Reply With Quote
Old 02-14-2016, 03:17 PM   #2
DoctorT68's Avatar
By the way 2016 Sunseeker 3050SF
Old 02-14-2016, 03:19 PM   #3
I had a similar problem and the slide out owning bracket was loose and getting jammed preventing the slide out from pulling out. White ring on awning.
bdifonzo is offline   Reply With Quote
Old 02-14-2016, 03:22 PM   #4
Awning
Old 02-14-2016, 03:28 PM   #5
rattleNsmoke's Avatar
Reel it back in then have a helper slowly extend the slide while you check around the inside to make certain the edge of the slide isn't hanging up on a cabinet door knob (ask me how I know)..*s. If all is clear and it still doesn't go out fully, repeat the process while outside, under the slide looking for something jamming it up. Last effort would be to use the crank and manually extend it to see if it's the motor getting weak. Maybe others can chime in with other idea's.
rattleNsmoke is offline   Reply With Quote
Old 02-14-2016, 03:54 PM   #6
GM
bclemens's Avatar
Can't manually extend the schwintec with a crank.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 02-14-2016, 07:15 PM   #7
DoctorT68's Avatar
Thanks everyone. I figured it out. It was these. Although I don't know what they do. Looks they they loosened up and got caught. Could someone tell me what they do and if I need to have it fixed before the long home on Froday, or can it wait?
Name:	ImageUploadedByForest River Forums1455495188.402899.jpg
Old 02-14-2016, 07:19 PM   #8
RedLdr1's Avatar
I had the same symptoms and my dealer replaced the front motor on the slide out. It was an intermittent problem that did not show an error light on the controller.
EDIT: I believe the parts you just posted a picture of are part of the slide out cover. Where did you remove them from?
Wayne and Christine
2020 Sunseeker MBS 2400Q On Order
RedLdr1 is offline   Reply With Quote
Old 02-14-2016, 07:35 PM   #9
That's what I was referring to. That was my problem. They only have one screw and come loose.
Old 02-14-2016, 07:44 PM   #10
GM
bclemens's Avatar
This are the anti billow devices.
