Old 04-12-2013, 09:54 PM   #21
TURBS's Avatar
Were u using a remote starter switch in the coach?
On my bosses class a there's a remote switch in the coach but also another switch in the gennie compartment.
Old 04-12-2013, 09:59 PM   #22
MotocrossCamper's Avatar
Yep, I was using the remote start. I went to check the one directly on the genny but no power there either.
Inside my battery compartment I have power to that starter relay but nothing to those 3 breakers
MotocrossCamper is offline   Reply With Quote
Old 04-12-2013, 10:06 PM   #23
TURBS's Avatar
Where that small terminal is on the starter relay is there power to that when start button is pushed?
Normally you would have power to one of the big terminals on relay until that little terminal is energized from start switch then it energizes the other big terminal on starter relay.
Old 04-12-2013, 10:07 PM   #24
TURBS's Avatar
You may not hhave power to those three circuit breakers until gennie is running.
Old 04-12-2013, 10:11 PM   #25
TURBS's Avatar
I don't want to tell you what to do here but.
If that is infact the gennie starter relay you should be able to jump across the to big terminals and it should start the gennie.
I just don't want you to mess something up especially this late at night.
What's weird is you have no 12v power from batteries.
Old 04-12-2013, 10:24 PM   #26
I though about jumping it but I'm not sure if that will solve my no fridge and no furnace problem. I think they both require 12 volt power
Old 04-12-2013, 10:28 PM   #27
TURBS's Avatar
Well with gennie running fridge should switch to 110 power ? But alas the circuit board I believe still runs on 12v.
There's a 12v fuse and fairly large somewhere that has blown .
Ill see if I can find a pic of what you might need to look for.
Brb
Old 04-12-2013, 10:34 PM   #28
TURBS's Avatar
Maybe something of this nature?
Old 04-12-2013, 10:44 PM   #29
I will investigate tomorrow but I started the RV for heat and the 12 bolt power mysteriously came back. I know it wasn't dead batteries because I checked them. Huh.... O well, all is good right now!
Thank you guys!!!!
Old 04-12-2013, 10:45 PM   #30
TURBS's Avatar
Thank you guys!!!!
Let me know what you find tomorrow!
Good luck!
