06-21-2015, 10:54 AM
Help ! Sunseeker 3170 Coach Batteries need jump start,
I need to jump start my batteries for the coach, there are two batteries down under the steps ( i lost my multi meter).
Any info on which ones I plug the jumper cables?
Here is a photo if helps.
P.S. This is a Ford Chasis 2014 (gas).
2014 SunSeeker 3170DS
Ford F-450
06-21-2015, 11:13 AM
geezer with gadgets
I have the same MH. 2011 edition. Near the floor of the drivers seat there is an emergency start switch. This will act as built in jumper cables for you to start the coach. Just hold it in the on position will turning the key and it will use the juice from the batteries in the step. Hope this helps.
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 57 2019: 30
06-21-2015, 01:08 PM
Sorry for some reasons my photos are not uploading.
Ford F-450
06-21-2015, 01:09 PM
Anyway you can post a photo? I am looking at mine, and cant find it.
Ford F-450
06-21-2015, 09:18 PM
If you need to jump start the engine, it is located on the left side under the hood. You jump start this battery.
As you look at the drivers seat, you will see a black switch down low. Press this switch, reach up and start the engine. If house batteries are strong enough, it will crank and start. Good luck.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
06-21-2015, 09:27 PM
P.S. This is a Ford Chassis 2014 (gas).
I'm not sure why you would need to "jump start" the coach batteries (you said the ones under the steps) unless it's to start the generator. You could use the emergency switch under the seat but the easiest way is to start the chassis engine which will then automatically connect the the 120 amp engine alternator to the coach batteries and rapidly recharge them. I once ran my coach batteries down so far that I could not start the generator. I started the chassis engine and after about 2 minutes was able to start the generator.
06-22-2015, 04:48 PM
that is what I am trying to do ( start the generator).
I did not have any luck finding this switch folks are talking bout.
Ford F-450
06-22-2015, 08:09 PM
Don't know where the switch is on your unit but if you start the engine on your MH and have the coach battery switch on, you should be able to start your generator.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
06-22-2015, 08:15 PM
Just FYI, here is the pic of my batteries.
Ford F-450
06-22-2015, 08:37 PM
As I said the easiest way is to start the chassis engine and it will provide enough power to start the generator.
As for the emergency switch just open the drivers door and look at the seat base near the floor. The switch is a large rocker type on the side of the base. This is true on my 2012. Don't know if they moved it or eliminated the capability on later units.
06-22-2015, 11:30 PM
Can't believe those batteries are only a year old. They look like they have been around the block a few times. Did you ever find the switch by the drivers seat?
1968 tent trailer
1985 Jamboree 23 ft
06-23-2015, 04:38 AM
They look worse in the picture then they are, no have not found switch but will look again this weekend as unit is in stirage, still need to figure out if they are 12 volt or 6 volt
Ford F-450
06-23-2015, 06:16 AM
They're connected in parallel. They are 12 volt batteries.
06-24-2015, 03:35 PM
The engine alternator will charge your house battery's
Make sure the Bat switch is on.
They will charge up enough to start the gen and then it will give them a good charge unless you are driving for a while and the alternator will fully charge them
If your engine isn't charging the house battery's you have other issues
Check your water levels
I had a cell that was almost dry before I got ready for my last trip and the house battery's drained quickly
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
06-25-2015, 09:54 AM
Cleaning those batteries will help too!
2011 Forester 3171DS Pic
SOLD!
New Rig: 2018 Tiffin 32SA
06-26-2015, 08:59 PM
I found the switch everyone was talking about, if it would have been a snake it would have bit me
Ford F-450
06-26-2015, 09:21 PM
could you possibly post a picture of the back side of that switch?
both of my wires came off and I don't know which goes where!
I would greatly appreciate it.
SOLD!
06-26-2015, 09:31 PM
Yep, it's dark out right now but I can post something tommorriw when I can get a hit in the daylight
Ford F-450
06-27-2015, 07:54 AM
Here you go
Ford F-450
06-27-2015, 08:16 AM
Thanks for posting the pic!!!
Too bad my wires are different colors
white/white-purple
SOLD!
