Old 12-23-2015, 03:36 PM   #1
Help with dewinterizing 3170
Hello Forum, I need some help quickly on this one. I just de-winterized my 3170 DS today with positive results on almost all fronts. I ran the anti freeze out of all the faucets except the bathroom faucet. I get almost zero pressure out of that faucet. All of the other faucets work fine including the shower. Did I miss something? I did it on city water and on the water pump.
Thanks for your help
Jagspe is offline   Reply With Quote
Old 12-23-2015, 03:40 PM   #2
RETIRED
n-e-d's Avatar
Sounds like a clogged aerator- remove and clean and you should be ok
Mary and Me
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Cargo Van HR DRW EXT DIY Daytripper "Red Roamer"
n-e-d is offline   Reply With Quote
Old 12-23-2015, 03:41 PM   #3
rmac04401's Avatar
Check your aerator it could be plugged. Unscrew from faucet and see if you got a blockage.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 12-23-2015, 03:46 PM   #4
Boom! Fixed. I cannot believe it was that simple of a solution. Thank you for the hep.
Old 12-23-2015, 04:33 PM   #5
A32Deuce's Avatar
It doesn't matter how many times you clean it, still happens!
A32Deuce is offline   Reply With Quote
3170, winter, winterize
