Old 07-24-2014, 08:30 AM   #1
Reinita's Avatar
Help with our new Blue Ox tow and braking system
In our Sunseeker 3170 right now, towing our automatic 2012 Jeep Wrangler Rubicon. Drives awesome.
We're curious what "number" you guys set up your brakes at.
The steps in the Jeep manual weren't very clear. Anyone have better instructions?
Also, any tips or things to look out for? Many thanks and happy camping.
Reinita is offline   Reply With Quote
Old 07-24-2014, 09:06 AM   #2
We tow a Pathfinder with our 3100 using a Blue Ox Patriot brake system. I set it on 9 most of the time. I back it off sometimes even to zero when in slow traffic. Also back it off to 5 in rain. I don't know if it would skid the tires at 9 but I fell better set that way.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
Old 07-24-2014, 09:30 AM   #3
We have a 3170 and tow my wife's cr-v. I have been setting it to 3. Most of our trips are very flat so I think we could get away without having it at all.
One problem we've had is that on long trips the cr-v battery tends to die. Our last trip we had to jump start it. We use a battery box to plug the blue Ox into, so I'm assuming the drain is from when the brake lights come on. Seems a little strange to me. When we stop I check to make sure the brake lights aren't stuck on, thinking that maybe I had the blue Ox too tight to the pedal.
Brian217 is offline   Reply With Quote
Old 07-24-2014, 09:41 AM   #4
abjb's Avatar
Check your Blue Ox owners manual.
Ours says to set it between 1 and 3 because we tow a hybrid.
I put a camera in the car and recorded a few stops.
After watching I changed the setting to 2 from 3.
ab&jb
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 07-24-2014, 09:50 AM   #5
RSchleder's Avatar
We use the Blue Ox Patriot system also. We tow a 6 speed Mini behind our Sprinter based ERA (class B) MH. I set the controller on 5 as any higher setting locks the Mini tires when I apply the ERA brakes,
As far as the battery goes, I had the same issue with the battery being run down after a 2 day, 900 mile trip. To correct the problem, I ran a charge wire from the "coach" battery to the rear of the ERA with a connector on it. I also ran a charge wire from the Mini battery to the front of the car and attached a mating connector. Now when I go down the road, my Mini battery receives a charge from the ERA battery and the dead battery issue in gone. You can goggle and find a wiring kit to do this job complete with connector, fuse, etc, to do the job. I did mine a couple of years ago it it continues to work perfectly!
PS- in my opinion, the Patriot system is what runs down the battery, not the brake lights as they should run off the tow vehicle battery.
RSchleder is offline   Reply With Quote
Old 07-24-2014, 12:42 PM   #6
We've towed for two days without starting the Pathfinder that we were towing. The battery ran down late one day and I realized that we had been on the road for almost three days. I plugged the Patriot into a portable booster battery and drove on.
Since we had an electrical hookup that night and the coach's Battery Control Center connects the coach battery and convertor to the chassis battery, I just ran jumper cables from the chassis battery to the Pathfinder battery overnight and fully recharged it.
Old 07-25-2014, 06:03 AM   #7
abjb's Avatar
Running the battery down on the Pathfinder will kill it, might take a few times.
Check the towing section in your Pathfinder Owner Manual, you should probably run the Pathfinder every couple of hours to lube the transmission which will keep your battery charged.
2012 Georgetown 360
Old 07-25-2014, 08:54 PM   #8
We have a driveshaft disconnect so no part of the automatic transmission turns while in tow.
RamblerGuy
2011 Sunseeker 3100
Old 07-26-2014, 06:54 AM   #9
abjb's Avatar
ops
I should have said Running the battery down on the Pathfinder will kill the battery, might take a few times.
2012 Georgetown 360
Old 07-26-2014, 08:48 AM   #10
Reinita's Avatar
Thanks for all the tips. We used it all day yesterday. Works great.
blue ox
