09-04-2015, 12:30 PM
Help with slide seal
I noticed the factory screws were not holding the seal behind my slide in place on my Sunseeker 3170. The dealership agreed to fix the problem before I purchased the RV. They added larger screws in between the factory screws and squirted a lot of goop around the edges. All the screws are now coming out, and the warranty is expired. The main problem is that there is not enough overlap between the seal and the wall of the RV to hold the screws. The screws are too close to the edge on the wall and all the screw holes are now a C shape. I am not sure if I should try a fender washer, nut and bolt, or try to find a bigger piece of wood or metal to screw into. Any help would be greatly appreciated.
Thank you,
Lowrey
09-04-2015, 01:03 PM
Hope your still under warranty !
Happy Campin!
Forester 2451s
09-04-2015, 01:09 PM
I am not under warranty.
I am hoping this is only a seal to keep dirt and rain out. If that is the case, I am not too worried about it. I haven't been able to put the slide out and check it yet.
I was wondering if anyone else had seen something similar.
09-04-2015, 01:15 PM
You bought the unit Used from a Dealership,and they did this kind of repair! Remove the flange and clean up the Mess they left and attempt a repair yourself! Youroo!!
09-04-2015, 02:25 PM
Class C Representative
A picture or two may help solve the issue.
09-04-2015, 02:50 PM
Plain Old Member
If that's the schwintek slide, you got problems. That's the whole slide out frame coming loose. Same problem has been on other threads here before with Forester / Sunseeker.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
09-04-2015, 03:37 PM
Look like a challenge to fix IMO. Sort out why those screw pulled out! Rotten wood or just stripped? Clean up as suggested and then move all the screws to ensure they attach to something solid. Patch to cover old holes. Good luck.
Happy Campin!
Forester 2451s
09-04-2015, 03:49 PM
That's a standard problem on the 3050s don't know about your model you will have to have rivets put in Forest River can give you the info on how to repair that
2015 sunseeker 3050s. 2007 saturn aura
09-04-2015, 03:55 PM
I should have said common problem not standard
09-05-2015, 12:05 PM
I'm really concerned about this being a problem with 3050S/3051S models, as we are planning a purchase of one probably in December. Joshua...is this an ongoing problem with this model? And is the factory doing anything regarding a product improvement to prevent it? Sometimes over-engineering something is much better than building junk.
Retired and loving it...Can't wait to get back on the road!
2017 Forester 3051S ("Farley")
Born April 18, 2016
Toad: 2014 Honda CR-V AWD
GO DUCKS !!
Jim & Diana (and 3 cats)
09-05-2015, 12:09 PM
If you can remove the flange, take a rivet gauge and, including the flange, see how deep the body of a rivet would be. If the holes are worn eccentric from the hardware moving, you can re-size the holes to a diameter that will accommodate a rivet. I would rent a pneumatic rivet puller and find a place that would sell you Cherry Rivets, which are used on aircraft. Before you pull the rivets, put a light coat of zinc chromate grease on the rivet body to prevent dissimilar metal corrosion. This should work as long as the flange is screwed to sheet metal, which from your picture, looks like self-tapping sheet metal screws. If they are screwed into wood, then you may have to find a small sized anchor bolt, which you insert through the holes. The anchor will deploy on the blind side, and then you can re-attach the flange that way. I am finding that when these coached are constructed, that little consideration is given to proper technique with regard to hardware and attachment. It is fixable, but you just need to take a little more time to figure things out than the people who put it together, who in my opinion are not mechanically inclined.If you can use a rivet puller, but are unable to find aircraft grade rivets, you can use automotive grade, using the same technique as mentioned. Take your time! Do it right, and you will never have to mess with it again.
09-05-2015, 12:22 PM
Ok, looking at it, the self tapper hex heads the dealer used are two large. Take a measuring ruler, and scribe a line with the known depth of the rouch opening onto the trim piece. Draw a line on that trim piece so you know where the edge of the rough opening is, after you close it tight to the opening. Then, with some sort of pattern, get smaller shank self tapers by taking one of the OEM ones to the hardware store to match it. Be sure to get non rusting self tappers. If your a tool guy at all, buy a impact driver, like Dewalt, it is truely one of those tools that come around every now and then that you say "wow" after use. The perfect application is this job, for that tool. Just sayin'
P.S. First, I'd clean up that old caulk and redo that, prior to re-attachment, like the other poster suggested.
09-05-2015, 01:29 PM
Slide seal
I found the same problem on my new 2013 Grey Wolf 28BH on arrival home from the dealer. The dealer repaired it with longer screws and so far it is holding well. I check it after every use of the slide out. Originally it appeared that there wasn't sufficient solid backing for the screws but after the repair it appears to be solid.
2013 Grey Wolf 28BH
2012 Ford F250 Super Duty Lariet 4X4
Nights camped 2015 = 36
09-06-2015, 06:59 AM
Are you ABSOLUTELY sure that nothing is under the bed that would jam and cause this?
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
09-06-2015, 08:34 PM
Same issue in my 3170DS. Waiting on CE to hear from FR.
R & J
2015 Sunseeker 3170DS
2007 Ford Escape Toad-5 spd manual
Blue Ox Alpha tow bar/Blue Ox Patriot brake
09-10-2015, 09:18 AM
Update:
I took the RV out this weekend. When the slide is out the gap closes. When I put the slide back in, the gap on the bottom opens back up.
It looks like maybe the top is pulling in more than the bottom causing the trim piece to angle out at the bottom.
I think I may need to reset the slide controllers so that it pulls in evenly.
The only way to get to the back side is to leave the slide partially in and reach around the edge of the entertainment center inside. Not easy!
I am still not sure if this piece's only purpose is to seal the gap or if there is some kind of function.
Hopefully a Forest River rep can educate me on this.
09-11-2015, 12:23 PM
It looks like when the RV was made they completely missed the wall when screwing in the slide mechanism. There isn't enough overlap to move the screws over, so I guess I am going to have to figure out a way to squeeze in something sturdy enough to screw into. Possible some angle iron or a 2X4.
The rep from Lippert was kind enough to send me a repair manual that will help when removing and reinstalling the slide bracket.
Here is a pic from inside, with the slide retracted.
[/URL][/IMG]
09-12-2015, 12:43 AM
Boy, they missed it by a mile! Can you slide the outer portion of the seal retainer over to go through the wood? There should be more than enough of the rubber seal to compensate.I would use aluminum instead of angle iron or wood. If you can pull the outer seal retainer into proper position, make sure that it is lined up properly (which they didn't), and drill pilot holes through the outer screw holes through the wood. Then once that is done, use 1/4 or 1/2 inch aluminum bar, maybe 2 inches wide, clamp it in place so that it doesn't move with C-clamps or something that you can work around the rubber part of the slide seal, and then mark it to match the holes. Take it back off and carefully drill the marked spots. I would use threaded bolts and locking nuts with washers (thin) to then attach the seal flange and seal to the wood. Once you are finished, I would use Pro Seal (two part) to seal the outside. It remains flexible from -65 degrees to over 150 degrees, and costs about $25- $35. Google Pro Seal 8805 (or 8806) and use that instead of silicon weather caulking. Use the one that has one part in a can and the activator on the lid of the can. First, you clean off the old silicon caulk with a box cutter blade and acetone or naphtha until the surfaces are nice and clean. Get all of the old silicon off.
Then using masking tape, tape off the retainer flange and about 1/4 inch on the surface of the coach where the retainer butts against. Mix your Pro Seal on a piece of cardboard by combining the two parts and stirring together with a small screw driver. Start at the top and with the screw driver blade, apply the sealant as evenly as you can in between the masked off area. If the Pro Seal starts setting up, mix up a new batch (don't go overboard with the amount). Once you complete sealing, take a small jar with some water in it and mix a little dish soap in. Stir it up, and then dip your finger in, and smooth out your sealant. Let it sit for about 45 minutes and then remove your masking tape. You will have a professional, aircraft grade seal job that will withstand any temperature you will ever encounter and will never leak. You can do it! Good luck! You will impress yourself and have a good quality repair.
09-12-2015, 11:46 AM
Joshua ??
Joshua ??
Born April 18, 2016
GO DUCKS !!
09-13-2015, 07:36 PM
Just wondering if anyone from FR ever replied not a chance that the question was overlooked maybe just a private message was sent, I am wondering I'm sure there are a lot of FR owners interested as well as future buyer prospects
