08-02-2015, 08:30 AM
help with trailer brake control options
looking for a trailer brake control for a 2014 ford e450 2860 sunseeker pulling a dual axel 14' inclosed bike trailer. and what kind of plug and adapter and place to mount it. any info and part numbers
08-02-2015, 08:34 AM
You can't go wrong with the Prodigy P3. You should be able to purchase the correct wiring harness for your vehicle where you buy the controller. Plug and play. It's the best.
Bruce
08-02-2015, 08:45 AM
FYI, the factory trailer wiring plug on my 2014 was up behind the coin tray to the upper right of the steering wheel. I used my Prodigy from my former MH and bought the correct wire harness. Fished the OEM wire harness down to below the
Steering wheel and mounted the Prodigy there. Some people say there isn't enough room there, but I haven't had a problem.
08-02-2015, 09:04 AM
use the rigid mount, not the one that might allow it to pivot. these inertia controllers dont like to flop around.
08-02-2015, 09:34 AM
Here's a link, that may help you, to an article (including photos) on installing a brake controller in a 2014 Ford E450:
08-04-2015, 08:12 AM
Would you recommend the same prodigy p3 for an 07 Dodge Ram 2500 6.7 diesel pulling a 2016 windjammer 3029W?
08-04-2015, 08:19 AM
Check you storage areas in the truck. Many times trucks with towing capabilities/packages, have the wiring harness needed included in a small plastic bag in glove box or storage area.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
08-04-2015, 08:26 AM
Yes sir I have that connector what controller would you recommend?
08-04-2015, 08:37 AM
Prodigy P3
TST Tire Monitors
2 100W solar panels
08-04-2015, 08:39 AM
Thank you price about $144 for that one, is that a good price?
08-04-2015, 08:43 AM
Absolutely. The P3 is the best aftermarket brake controller I have ever used.
Bruce
08-04-2015, 08:45 AM
Sounds about right. Buy it from eTrailer so you have good support in case you have questions.
Bruce
08-04-2015, 08:47 AM
OK thanks I was just getting ready to ask about etrailer if it was a good company?
08-04-2015, 08:51 AM
You can never go wrong with eTrailer.
Bruce
08-04-2015, 08:52 AM
Thanks everyone just ordered.
