11-23-2015, 09:58 PM
Hooking Dish Tailgater through connection by shore power
Can I hook my dish tailgater using the cable connection near the 30 amp powesupply, I know it works for cable, just unsure if it is the right kind of cable to transmit satellite signal
2014 SunSeeker 3170DS
Ford F-450
11-23-2015, 10:06 PM
You don't have a satellite hookup?
11-23-2015, 10:38 PM
Berkshire 390QS
Should work fine, providing there is not a spliter in the line some where. We have to run a seperate line since there is a splinter going to the back TV.
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
2019: 156 days (2009 Berkshire, 390QS, and toad)
11-24-2015, 11:13 PM
Maybe the new Sunseekers have a separate satellite connection, mine does not.
2014 Sunseeker 3050S
Honda CRV (TOAD)
11-24-2015, 11:59 PM
Mine doesn't carry the dish signal. Run a flat line through a side window. Have a mod in the works for that.
11-25-2015, 12:38 AM
Do any of you use an inverter or have full hookups for power? Where do you have the satellite receiver? My connection is probably like yours, it only works for cable.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
2020 Camping 0 trips Cancellations 6
11-25-2015, 01:12 AM
Left Coast
On my 5er, I ran my own feeds to where ever I wanted... RG 6 cable and a few fittings from HD....Also made a front and rear mount for ant. (dish....King Flex auto) so that no cables would be lay'n on ground to be tripped over at night....With 2 TV's I also have 2 receivers, 1 for inside tv, other for outside. So, it can be done.
11-25-2015, 01:25 PM
Satellite
Yes you can if it is a newer model there are post on the forum I think under satellite in I posted exactly what I did with help from bclemmens I had satellite on 3 tv's with one receiver having problems with Forest River site on my phone can't go to forum from there site but if you send me a private message with email I will send you a picture of instructions
11-25-2015, 02:46 PM
Boso, do you have any idea what these work? Why the loop?
11-25-2015, 03:50 PM
The loop connects the TV to either the cable connection on the side or the connection on the roof. The roof is the terminal that is not connected. You can use either of the outside connections to hook up the tailgater.
11-25-2015, 04:16 PM
Satellite in
Yes Sage the tailgater goes into the cable in connection on Rv the loop has to be taken off and put back on when cable is used receiver line in goes to top of loop receiver line out goes to bottom also the hdmi cable has to be connected to receiver and tv put tv on hdmi 1 this is the main tv the others work on channel 3 receiver off for antenna or cable change all the channels from the one receiver only plays one channel at a time what ever the receiver is on but we only watch one at a time all three of mine work perfect this way
11-25-2015, 04:44 PM
27rlws
My 2015 Flaggstaff 27rlws has a cable line and a separate sat line-they are next to each other.
11-25-2015, 04:51 PM
Satellite in
This works on the Sunseeker and Forester don't know about anything else
11-25-2015, 07:03 PM
No.
Ford F-450
11-25-2015, 08:36 PM
Satellite in
Retired Air Force did you get my message that I sent you
2015 sunseeker 3050s. 2007 saturn aura
11-25-2015, 09:24 PM
Satalite
No the cable is to thin
11-25-2015, 09:35 PM
Yes Sir
Thank you
Ford F-450
11-25-2015, 09:40 PM
Here is the directions I hope . And remember that the hdmi cable has to be in the tv to the receiver in order for anything to work my tv above bunk on hdmi1 tv in br on channel 3 tv out side on channel 3
11-25-2015, 10:03 PM
My booster button is at the plate on the wall where the tv is plugged in at a very small button when on green light where the antenna jack is almost have to get at eye view to see it if you don't know where it's at I had to get on bunk the first time I saw it couldn't spot it until I knew where it was it has to be off also for clear cable to play
11-25-2015, 10:32 PM
It may be hidden. My Sunseeker doesnt have the bed over the cab, more of an entertainment center.
Ford F-450
