Old 07-19-2016, 04:46 PM   #11
Hooked up wrong
I have a Forest River Silverback 2016. I have to use a splitter and hook up to the Sat connections 1 & 2 to get cable on both TV's. I also have to move the cable connections behind the TV. Wired up wrong at factory. Haven't had a chance to change yet
okiegals is offline   Reply With Quote
Old 07-19-2016, 06:30 PM   #12
Thanks so much! It took the combination of first using the switch as described and then using the remote to program in the channels. Thanks to all who contributed. Great community.
rhenage is offline   Reply With Quote
Old 07-20-2016, 12:39 AM   #13
benagi's Avatar
Question, can you still get cable channels without a cable box?
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 07-20-2016, 01:40 AM   #14
Moderators' Assistant
bikendan's Avatar
Yes, If you're at a campground that offers cable tv.
Dan-Retired Firefighter/EMT
2016 PrimeTime TracerAIR 255, pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 07-20-2016, 07:16 AM   #15
We had great success with cable, until this year. Through process of elimination, have determined the wiring is now bad somewhere between the cable input Jack where you attach the campground cable and the TV. As a work around we use a longer cable and run through the window. Have no idea how to replace the bad wire.
Pam & Steve
2006 Lexington 283GTS
towing a Harley or a Vue
frogsandhogs is offline   Reply With Quote
Old 07-20-2016, 07:42 AM   #16
Herk7769 has good suggestions. Only other obvious suggestions are to check security of connections, confirm with the RV Park or with others as to the quality of their cable TV transmission, and also check quality of your physical cables.
pkeene is offline   Reply With Quote
Old 07-29-2016, 08:13 PM   #17
When using the antenna do I have to do a "search" on menue in order to rec antenna channels??????
Jim in Halifax is offline   Reply With Quote
Old 07-29-2016, 08:33 PM   #18
Search
Yes. Go to the menu and make sure antenna is selected and then do a search. I do a new search each time we change campgrounds.
Old 07-29-2016, 09:33 PM   #19
Yes, each time you move you will need to do a new search. Don't worry, it will soon be part of the routine and you won't have to think hard about it!
Pam & Steve
Old 07-30-2016, 09:46 AM   #20
Jim....when using your roof antenna, do search for "AIR" channels. When on the RV cable system, do same search but for "CABLE" channels. Hope that helps.
