Old 07-18-2016, 09:19 PM   #1
Hooking to cable tv line
Can anyone tell me what needs to be done to to switch from antenna to the cable once the cable line is hooked up? I can't get anything but my antenna. I have switched off the booster on the antenna, but that didn't do the trick. I have a 2015 Sunseeker 2860.
rhenage is offline   Reply With Quote
Old 07-18-2016, 09:49 PM   #2
Usually Confused Member
emm-dee's Avatar
Did you access the menu function on the television and have it scan for "cable" channels?
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
Old 07-18-2016, 09:50 PM   #3
Exactly what I was going to ask. I have to reprogram my tv when I change source.
2004 silverado 2500HD ext cab short bed
2012 Rockwood 8280WS
Herms1960 is offline   Reply With Quote
Old 07-18-2016, 10:11 PM   #4
SeaDog's Avatar
X3
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 07-19-2016, 04:35 AM   #5
ilmor's Avatar
Using the TV remote, go to its settings. Change the source from "Air" to "Cable".
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 07-19-2016, 07:02 AM   #6
Near your main TV there is white wall plate that the TV is connected to, it should have a light and a small button. Push the button to turn off and that should switch input to the cable input.
dmersereau is offline   Reply With Quote
Old 07-19-2016, 07:33 AM   #7
geeman53's Avatar
X2 - a small black button to the right of the 12 volt plug in. That is the cable input. Unpressed , the TV is on roof top antennae , depressed -on cable. Afterwards, go to TV cable scan. Done !
2016 sunseeker 2250slec
1988 Jayco p.u.,Coleman Plantation p.u.,1989 Jayco class c, Coachman TT,1995 Little Eddie fthwheel,2007 Heartland Sundance 2500 lS fthwheel
geeman53 is online now   Reply With Quote
Old 07-19-2016, 12:56 PM   #8
I have a 2016 Sunseeker and had the same issue. Two things must be done, one of which you did, ie, turn off the booster. Then go to menu on the TV and do the channel scan for CABLE. Be sure not to select "AIR".....it must be for CABLE. Then after a variable amount of time, the scan will find and store the cable channels. See your TV manual on how to set up "favorites" once all of the channels have been stored. That way you can easily select your desired channels via the "F-List" key on your remote.
pkeene is offline   Reply With Quote
Old 07-19-2016, 04:13 PM   #9
I've pushed all the buttons, programmed the TV's to cable and STILL bever get a decent cable signal!
Blest with a Coachmen Prism 24G
I Simpson is offline   Reply With Quote
Old 07-19-2016, 04:26 PM   #10
Herk7769's Avatar
Make SURE the wall plate light is OFF to get cable.
Make SURE you are using the "CABLE" connection outside and not the SAT.
ID:	114690   Click image for larger version
Name:	Winegard wall plate rear.JPG
ID:	114691   Click image for larger version
Name:	CBL and SAT inputs.jpg
HAM CALLSIGN - KC3FFW
