Old 04-14-2014, 06:20 PM   #1
Hoglou's Avatar
Hot water
There is a hot water drain cap (under pressure) under the right rear of the coach (2300). What happens if it breaks and where can I find a replacement?
Hoglou westGA
KM4HQQ 146.640mhz
Old 04-14-2014, 06:58 PM   #2
MotocrossCamper's Avatar
Is it just a little white plastic screw on low point drain cap like this?
Name:	ImageUploadedByForest River Forums1397519788.602054.jpg
If so you can get it at any RV store. I have even seen some bigger walmarts that carry them. You need to unhook your hose or shut your pump off (which ever you are using) and open a faucet to relieve the pressure before replacing.
MotocrossCamper is offline   Reply With Quote
Old 04-14-2014, 07:32 PM   #3
It is PEX pipe. You should be able to find it at any hardware or big box store.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
hot water, water
