Old 09-17-2016, 05:41 PM   #11
[QUOTE=Frankie Z;1318228]After feeling around I found the inlet valve handle laying under the heater duct( nice job forest river) .
Now I have to figure out a way to somehow squeeze my arms in the confined space to reattach.
Yep, like it would have been hard to have all valve stems face the same way when they were installing the valves/lines. That makes it both visually and operationally easier to understand and operate the valves.
Calgary, AB Canada
Ridenfun is offline   Reply With Quote
Old 09-19-2016, 06:15 PM   #12
Put the inspection covers back on with Velcro. That way you do not have to use the screws each time and access is much easier.
Brandon2
2500 TS Sun Seeker
brandon 2 is offline   Reply With Quote
Old 09-19-2016, 07:45 PM   #13
Frankie Z's Avatar
Brandon2
2500 TS Sun Seeker
That's a good idea thanks
Frankie Z is offline   Reply With Quote
Old 09-21-2016, 02:28 AM   #14
The Velcro is a good idea, I'd just done it this weekend. I'd used some "industrial strength" Velcro I had on hand, but it's really more than is needed, the narrower standard product would have been fine, and come off a bit easier, and I just used some tabs, not a continuous run of Velcro around the entire opening.
Calgary, AB Canada
Old 09-21-2016, 08:34 AM   #15
Chief tinkerer
Gidyupgo's Avatar
Won't be the case with everyone, but once I found out where they were by pulling the panel, I discovered I can open the door under the sink, pull out the drawer next to it and reach all three valves.
Gary
2017 SunSeeker 3010DS
Gidyupgo is offline   Reply With Quote
Old 09-22-2016, 05:03 PM   #16
Likewise:
2016 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
brucemc is offline   Reply With Quote
bypass, hot water, water
