Old 09-15-2016, 02:55 PM   #1
Frankie Z's Avatar
Hot water bypass help
Name:	ImageUploadedByForest River Forums1473965433.940342.jpg
I have attached a picture of the 2 valves related to my hot water heater. Which way should each valve be turned to bypass the water heater. I have opened water heater drain plug and attached city water. I have tried different combinations, perp and horz but water still flows from the water heater drain plug opening. I would appreciate any help that can be offered. Last year I ended up having to fill water heater with antifreeze.
Frankie Z is offline   Reply With Quote
Old 09-15-2016, 03:02 PM   #2
Location: Minnesota ( wishing we were boondocking in the New York Catskills )
The Mind-Set on the valves is very straight-forward.
If the handle is in-line or parallel with the pipe, think "like a straight line" then it is OPEN.
If the handle is "across" the pipe (like a T or an L or a + plus-sign) then it is CLOSED.
Hope this makes it a little easier to remember ...
For NORMAL operation, CLOSE the bypass pipe and OPEN the inlet and outlet pipes.
For BYPASS - Winterizing - CLOSE the Inlet, Close the outlet, and OPEN the bypass.
In your picture, the one BYPASS is the one that has BLUE on bottom and RED on top. The cold INLET has blue-blue and the hot OUTLET has red-red.
Best Luck !!!
Jeff and Abby
Fur Babies - Xandra Sophia (GSD) and Neo (Min-Pin Mutt who thinks he is a cat)
2015 Tracer Air 235 (previous 1994 Veri-Lite 1130 TC)
1998 Dodge Ram 2500 Quad Cab - 360 - 46RE (Built)
Jeff_and_Abby is offline   Reply With Quote
Old 09-15-2016, 03:12 PM   #3
Frankie Z's Avatar
It appears I do not have a valve to close the inlet to the water heater
Old 09-15-2016, 03:12 PM   #4
clr
From your picture it looks to me like you are currently in the Normal mode with the water passing thru the water heater. So like Jeff said open the bypass valve blue red piping the handle should be in line with the pipe, and close both the red red and blue blue valves (the handle should be across the pipe and not in a straight line with the pipe.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 09-15-2016, 03:13 PM   #5
Here is an edit of your picture, clearly the hot valve is OPEN and the bypass valve is CLOSED.
The view of the cold valve is a little obscured by the air ducts below it.
( please forgive my poor mouse / whiteboard skills. )
Jeff and Abby
Old 09-15-2016, 03:14 PM   #6
Head Rambler
You said that you have two valves, but you actually have the conventional 3-valve setup.
Close the hot (red) and cold (blue) valves (handles perpendicular to line), and open the bypass (red one side, blue the other side) valve (handle parallel to piping). That bypasses the water heater. Then you can add antifreeze and drain the tank.
Here's how they should look.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 09-15-2016, 03:20 PM   #7
Frankie Z's Avatar
After feeling around I found the inlet valve handle laying under the heater duct( nice job forest river) .
Now I have to figure out a way to somehow squeeze my arms in the confined space to reattach.
Great and thanks for all the help from you guys.
Old 09-15-2016, 03:24 PM   #8
Frankie Z's Avatar
Guess I have to remove bottom panel
Again thanks for the help
Old 09-15-2016, 04:25 PM   #9
Head Rambler
Sometimes you need Go-Go-Gadget arms in some of the places you have to get to in these RV's!
Good luck getting it all fixed and set.
Gotta go campin!
Old 09-15-2016, 06:24 PM   #10
Hoglou's Avatar
Consider adding something like a attwood access plate. My coach came with one one the bed frame to access the HW lines....
Hoglou westGA
KM4HQQ 146.640mhz
bypass, hot water, water
