08-31-2014, 09:21 AM
Hot water heater
I have a 2104 Sunseeker 2860DS and when plugged into electric I always have hot water without having to turn anything on. Is this correct or is there something wrong with unit? My TT I used to have I would have to turn on switch. What is switch on panel for...gas?
08-31-2014, 09:28 AM
Yes, the panel switch only enables the propane mode. The electric mode is enabled by a switch on or close to the heater itself. The manual for the heater that you got in that pack of manuals with the RV will show you where it is.
You should always turn off the electric switch when not using the RV and especially when draining because the element will burn out very quickly if the tank is not full of water.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
08-31-2014, 09:29 AM
You will usually find the AC heater switch located inside the hot water heater panel outside the camper. If it's in the on position you will get hot water any time you're plugged in to shore power.
The switch on the inside panel is for the gas heater. Either way, always make sure there's plenty of water in the hot water heater before using.
Ken
08-31-2014, 09:30 AM
Yeah that's the way it works. The switch for the electrical circuit in on the heater panel itself, sorta nestled behind the pressure relief valve. The switch you showed is for gas.
Beware the electric switch, its awful easy to overlook (as I've done) when one drains the water heater (for winterization etc). If it hasn't been turned off, you'll burn out the heater element and likely a sortof fuze circuit nestled in behind.
08-31-2014, 10:12 AM
By the way, you can use electricity and gas at the same to heat water. They work on separate thermostats and both will come on if the water gets cool enough. This reduces the recovery time, if that's important.
In case you don't already know, the shore line or generator can supply 30 amps, which is enough to run two of the three main loads: water heater, A/C - heat pump, and microwave oven. Neither power source can run all three at the same time. You need to turn one of the three off when you run the other two.
08-31-2014, 06:29 PM
I have an '06 Sunseeker and for the life of me, there is no switch to select gas or electric. Is this an enhancement for later models?
08-31-2014, 09:57 PM
Commercial Member
If there is one...it is outside on the water heater itself. We did not move the switch inside until we switched to Atwood water heaters this pas year.
Open outside water heater door..should be a toggle switch.
08-31-2014, 10:15 PM
If you have the Suburban brand water heater, this FAQ may help:
http://www.forestriverforums.com/for...ore-36197.html
2011 Flagstaff 831 RLBSS
09-01-2014, 03:54 PM
Found it...hiding behind the gas inlet. Thanks, bclemens.
09-01-2014, 07:37 PM
Like some here going outside to turn on/off the water heater's electric element when you need to run the AC, microwave, and coffee pot didn't work for me. Bending over, opening up the circuit breaker panel and flipping the water heaters breaker to off was only slightly better, but still got old. I added my own switch to easily turn on/off the electric heating element.
This I can explain to my wife on how to turn on/off before she starts to do her hair and trip a breaker I have to go outside in the rain, cold, heat to rest.
Love our Forest River, but they should have more wife's on their design and model approval teams. They should share in some of the pain and blank stairs us husbands live with when explaining how RV systems work and why you can't do "X" in a motorhome like you can in a sticks and bricks.
I challenge any engineer to explain to my wife why the on/off switch has to be outside in a secluded location behind a panel in the morning before she's done her hair or had her coffee!
2011 Sunseeker 3170DS - 30,000 miles explored
09-01-2014, 07:49 PM
So use the propane option instead of the electric. Problem solved.
09-01-2014, 07:52 PM
X2 It makes life so much easier. I put in an illuminated switch so it's a great reminder to turn it off. Hidden outside it's really easy to forget about.
Just a reminder when running on electricity... the indoor water heater switch should be off. Otherwise you're running both the electric and gas burner. Which can be nice if you want hot water fast, but if your trying to conserve your propane, not so desirable.
09-02-2014, 04:43 AM
Suburban water heaters are the problem. FR has now changed to Atwood WH which has electric switch inside along with propane switch.
2012 Forest River Sunseeker 2300 Chevy
09-02-2014, 03:59 PM
Commercial Member
Yeah after we switched over to Atwood. Suburban came in and said "well hey, we have an option for an inside switch as well".
Hey, awesome to know now that we have switched every print to fit this different sized water heater. And you can contemplate your failure to let us know that, while they get our 85 water heaters a week.
09-02-2014, 09:11 PM
I would love to install a switch indoors around the kitchen sink area. Is there a kit to do this? I have the 3170, so the heater is to the right of the drawers. I'm assuming it couldn't be too hard to run something like that. I like to do projects myself if I don't think they're over my head. Would you have to splice wires in somewhere on the water heater or would it be a "plug and play" type of thing? I know you can hit the breaker to turn it on and off, but I would rather have a switch in the kitchen.
09-03-2014, 06:03 AM
There is also a circuit breaker labeled elec. water heater located in the WFCO power distribution panel. I use that to turn my electric element on and off versus the switch outside.
We've been quite satisfied with the heating of elec. only for the 3 of us. Seldom use the propane.
Bobby
