Old 07-31-2015, 05:30 AM   #11
Electric
I have a 30 amp, & I leave my on all the time with my fridge, & AC. Now if I use my microwave, I do turn off the AC until I'm finished. Then I turn my AC back on, never had any issues.
hollandti is offline   Reply With Quote
Old 07-31-2015, 08:34 AM   #12
water heater
I have a3170ds also. we use wh on propane all the time .it uses so little its not noticeable.saves more space for on electrical side so no problems with breakers
sonny bransom is offline   Reply With Quote
Old 07-31-2015, 09:00 AM   #13
Sagecoachdriver's Avatar
Which model water heater does FR put in the Forester/Sunseeker? I thought they were Suburban, but the one I saw at the dealer was Atwood. Could be seeing things??? No anode rod or electric rod, just the vinyl white plug to drain.
Sagecoachdriver is offline   Reply With Quote
Old 07-31-2015, 11:05 AM   #14
Originally Posted by Learjet View Post
and just because it wasn't said...it's a water heater...you are not heating hot water
"Hot" is relative.
Iwritecode is offline   Reply With Quote
Old 07-31-2015, 11:31 AM   #15
Fulltime family RVer
Originally Posted by Iwritecode View Post
"Hot" is relative.
Agreed. Just because the water cooled enough to be reheated doesn't mean that it isn't still "hot".
But, I've also never understood the need to correct this one. Same with being pedantic over propane tanks vs. cylinders vs. bottles.
Old 07-31-2015, 11:32 AM   #16
benagi's Avatar
We have the Atwood on our 2016. I think 2016 and newer will all have Atwoods.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 07-31-2015, 11:57 AM   #17
Georgia Frog Rally 2018
aceinspp's Avatar
I use my all the time on propane. I have never emty a propane tank during a camping season I do not leave the switch on so the system runs constantly I turn it on as needed. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 07-31-2015, 01:27 PM   #18
mine is a2014 .not sure which brand, it does have elect rod to take out to drain tank,,,i will ck brand
Old 07-31-2015, 02:33 PM   #19
The reason I asked, is because my current MH has an Atwood water heater and the temperature was way too hot for us. I purchase online the adjustable thermostat and set the temperature down as low as it would go to the letter "A". It delivers water at 117 degrees instead of 155. Since it's just the DW and myself, we've never had a problem running out of hot water showering. I did purchase a spare thermostat and am saving it for the new Forester, hopefully with an Atwood water heater.
Old 07-31-2015, 02:55 PM   #20
Because the proper term is water heater.
heater, hot water, water, water heater
