07-30-2015, 08:44 AM
Hot water heater questions
Ok, so taking out the 3170ds for the first time this weekend. I have a couple of questions about the hot water heater.
Do you run it all the time?
Secondly I read a ton on tripping breakers, and it seems that I may want to run it on Propane. Please give thoughts on that. Also, how do you do get it to run on propane while plugged in? Turn off a breaker or something?
Just seems like a really complicated thing that I did not consider regarding having hot water all the time or not. If it is all the time on propane, I would think I would use an excessive amount of propane...
07-30-2015, 08:49 AM
If you have the Suburban water heater, this FAQ should help explain it all.
http://www.forestriverforums.com/for...ore-36197.html
The water heater has thermostats similar to your water heater at home, so it's not heating all the time....but just when the water temp falls below a certain temp (usually 130 degrees).
2011 Flagstaff 831 RLBSS
07-30-2015, 08:55 AM
Lots of options. If you have shore power, I would run on electric. You just need to be aware of total power usage as you have a limit 30A or 50A depending on your unit. If you are running AC WH you might need to turn one off to run microwave. We leave our WH on all the time but if you are on propane, and only need hot water once or twice a day, turning it on and off may be an option. No hard and fast rules. Do what works for you,
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
07-30-2015, 08:57 AM
If you are aware of your electrical use and shut down the electric HWH when you have other high electrical demands, you will not trip breakers. This is my first electrical HWH and it sure does save on propane by using the electrical section
Of the HWH as much as possible.
07-30-2015, 09:02 AM
I decided a long time ago that the hassle of worrying about it being left on was not worth the propane. I leave it "ON" and on propane all the time. I have gone out and switched the AC on as well when we have guests and know there will be a lot of showers and need faster "recovery time"; then I shut the AC back off.
It does not use near as much as you might think in a week or so of camping. Longer than that and we are boondocking and no shore power anyway.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
07-30-2015, 11:17 AM
Thanks for all the information everyone! I will go with A/C since that is free. If i start tripping breakers, I will switch to propane. I do think I will be leaving it "On" all the time though.
07-30-2015, 12:00 PM
Run mine 30 minutes before I need it on electricity never use lp unless dry camping don't have any problem with breakers never run mw hw and ac at same time it were 50 amps could run everything
2015 sunseeker 3050s. 2007 saturn aura
07-30-2015, 01:16 PM
I leave the "outside" HW electric switch "on" all the time. Use inside breaker box to turn the HW electric on or off. Leave it "on" throughout the day/night except when preparing meals using the microwave. Then cut if off for the duration of the meal. Water is already hot, so do not miss it for the short time it is off. Takes a few times of waking to a cold shave, after that you remember to flip it on when going to bed. Save the propane to use for frig while traveling, and the occasional dry camp HW.
07-30-2015, 05:35 PM
I run on elect. if available. Once hot, turn off, turn back on 5 min prior to shower. In summer, it will stay hot almost all day, even when off.
07-30-2015, 05:37 PM
and just because it wasn't said...it's a water heater...you are not heating hot water
-2017 Ram Cummins, Aisin DRW 3.73, 4x4
-2015 Wildcat 317RL
-B&W Companion , MorRyde pinbox
07-31-2015, 05:30 AM
Electric
I have a 30 amp, & I leave my on all the time with my fridge, & AC. Now if I use my microwave, I do turn off the AC until I'm finished. Then I turn my AC back on, never had any issues.
07-31-2015, 08:34 AM
water heater
I have a3170ds also. we use wh on propane all the time .it uses so little its not noticeable.saves more space for on electrical side so no problems with breakers
07-31-2015, 09:00 AM
Which model water heater does FR put in the Forester/Sunseeker? I thought they were Suburban, but the one I saw at the dealer was Atwood. Could be seeing things??? No anode rod or electric rod, just the vinyl white plug to drain.
07-31-2015, 11:05 AM
"Hot" is relative.
07-31-2015, 11:31 AM
Always Learning
Originally Posted by Iwritecode
"Hot" is relative.
Agreed. Just because the water cooled enough to be reheated doesn't mean that it isn't still "hot".
But, I've also never understood the need to correct this one. Same with being pedantic over propane tanks vs. cylinders vs. bottles.
07-31-2015, 11:32 AM
We have the Atwood on our 2016. I think 2016 and newer will all have Atwoods.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
07-31-2015, 11:57 AM
Georgia Rally Coordinator
I use my all the time on propane. I have never emty a propane tank during a camping season I do not leave the switch on so the system runs constantly I turn it on as needed. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
07-31-2015, 01:27 PM
mine is a2014 .not sure which brand, it does have elect rod to take out to drain tank,,,i will ck brand
07-31-2015, 02:33 PM
The reason I asked, is because my current MH has an Atwood water heater and the temperature was way too hot for us. I purchase online the adjustable thermostat and set the temperature down as low as it would go to the letter "A". It delivers water at 117 degrees instead of 155. Since it's just the DW and myself, we've never had a problem running out of hot water showering. I did purchase a spare thermostat and am saving it for the new Forester, hopefully with an Atwood water heater.
07-31-2015, 02:55 PM
Because the proper term is water heater.
