Old 04-14-2013, 04:16 PM   #1
hot water low point on 3170ds
Hi, just took delivery on a 2014 3170ds. Not my first camper, is my first c. Found a low point drain behind rear axle on passenger side, next to it is the fresh tank drain line. But there should be two drains, one hot, one cold. Could the hot water tank be considered the hot water low point? If not I have not a clue where the drain may be. Thanks for any insight.
Jim182 is offline   Reply With Quote
Old 04-14-2013, 11:09 PM   #2
GM
bclemens's Avatar
You are correct. there is only a cold low point last time I checked. Then the anode rod for the W/H.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 04-15-2013, 11:54 AM   #3
Plain Old Member
Wonder why there's not a hot and cold low point? Every RV we've had before had both. Even my FIL's little 18' Jayco has both. Pretty nice, if the relief valve was open on the WH, it'd almost syphon most of it out. Brian, being there are hot water lines lower than the WH, might suggest adding a low point to the hot line too. Cheap add on, cheap insurance. Could probably drain some of it out of the outside shower. Never paid much mind to it on this one, but I'll probably add one now that I know this.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 04-15-2013, 01:12 PM   #4
GM
bclemens's Avatar
I'm double checking it with production...just to see what they say.
Old 04-15-2013, 01:39 PM   #5
GM
bclemens's Avatar
I stand corrected. there is a HOT and a COLD low point drain. One is red (hot) other cold (blue)
The hot (red line) has a cap on it under the unit there is no shut off on the hot line.
Old 04-15-2013, 08:19 PM   #6
You probably have one since my Sunseeker 3120 has both drains.
ATVer is offline   Reply With Quote
Old 04-16-2013, 11:21 AM   #7
Plain Old Member
I probably do. Just haven't ever needed it yet, so haven't paid it as much mind. I'm sure I'll look closer when I get back home, and go ahead and add the valves. The to do list has gotten longer faster than I can actually do stuff. Trying to narrow the list down as we may be selling it next year anyway. Possibly selling home and going back to fifth wheel / full timing. Guess all the mods will put somebody else ahead of the game.
