Old 10-01-2016, 05:17 PM   #1
JD57's Avatar
Hot water tank shutoff location
Although we're heading down to Yuma in late December, being from Canada we'll still have winterize our new (to us) RV before our departure. We have a 2026/15 Sunseeker 3050CDS. I've have located the main drains easily ( and thankful it has an anti freeze input tube as per picture) but I cannot find the actual inside shut off valves for the HWT. Would appreciate if someone has/familiar with this coach and can tell me where to look. The only inside panel located so far was inside bedroom wardrobe but this was access to shower valves. Thanks in advance.Click image for larger version
Name:	ImageUploadedByForest River Forums1475356664.360906.jpg
2016/15 Sunseeker 3050DS-CD
Ford E450
JD57 is offline   Reply With Quote
Old 10-01-2016, 05:25 PM   #2
Ford Idaho's Avatar
Looks like what you are wanting is in your picture, the valve handles appear to be green in color to my old eyes.
One is within the top loop of the AF tube then another is on a metal fitting just above the top loop.
Old 10-01-2016, 06:28 PM   #3
JD57's Avatar
Thanks for the reply. I've located the HWT for the 3050. Access is thru removable wood panel under fridge. Then HWT has three valves. Summer has both side valves open, with centre closed, and for winter the side valves are closed ( perpendicular) and the bypass -centre is open ( parallel) pictures attached to help anyone else. BTW thanks to all the readers here as the responses on this forum are fantastic. Cheers. John Click image for larger version
Name:	ImageUploadedByForest River Forums1475360833.702798.jpg
ID:	121853Click image for larger version
Name:	ImageUploadedByForest River Forums1475360854.288649.jpg
ID:	121854Click image for larger version
Name:	ImageUploadedByForest River Forums1475360866.084707.jpg
Ford E450
cat, hot water, location, tank, water, water tank
