Old 11-07-2017, 04:59 PM   #1
House Batteries
Hi all,
I have a question about the house batteries, we purchased a preowned 2013 Sunseeker 3010 DS, the unit is at a outside storage facility with no shore power, it's in Pennsylvania so it's going to get pretty cold this winter. Should I remove the batteries and bring them in the house and put them on a trickle charger or is it okay to leave them in the RV for the winter?
TIA
Chas69 is offline   Reply With Quote
Old 11-07-2017, 05:26 PM   #2
Hoglou's Avatar
Trickle for the battery and peppermint for the mice....
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 11-07-2017, 10:31 PM   #3
Garrette's Avatar
Yep
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 11-07-2017, 11:39 PM   #4
Funny. Does peppermint keep mice away?
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
mwdilday is offline   Reply With Quote
Old 11-08-2017, 07:48 PM   #5
JoeSteiner's Avatar
I have a 2025 sunseeker 2400r class c RV. The batteries will only last about 2 days because of the propane sniffer. If it was me, I'd take them out and bring them home and put them on a trickle charger. Not good for them to get totally discharged.
JoeSteiner is offline   Reply With Quote
Old 11-08-2017, 08:07 PM   #6
Peppermint oil , not the candy version
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 11-08-2017, 08:45 PM   #7
Bluepill's Avatar
Batteries will be happiest if removed and fully charged and then connected to a maintainer at your home.
You can also leave them in place, fully charge them, disconnect them, and add a solar charger.
Example:
https://www.homedepot.com/p/Coleman-...8033/203241551
Old 11-09-2017, 12:02 PM   #8
Thanks everyone, think I'm going to bring them inside for the winter, might be a little extra work but it might be worth it.
Old 11-09-2017, 12:56 PM   #9
MNtraveler's Avatar
You can remove them, but it's really not necessary (and can be a negative as discussed below).
What is necessary is to disconnect the batteries so there is no trickle drain on them from items like the radio memory or CO/LPG detector. This is done with a battery disconnect switch installed on the negative or ground side of the battery combo (be sure it's the ground line that covers both batteries so you don't leave one connected).
You can use one like this, although the exact model that will work for you depends on what kind of batteries you have (how the terminals are set up - top vs. side - and how the ground wire is attached):
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
We have left ours outside in Minnesota where it can get to -20 or worse and not had any problems and almost no battery drainage when disconnected. Just stop by now and then, CONNECT the batteries, fire up the generator and run it at at least 50% load to exercise the generator and keep it from gumming up. If you remove the batteries, you will not be able to even start the generator. The generator will not only top up the house batteries but also top up the engine/chassis battery too (based on how the Battery Control Center works). So you will kill 3 birds with one stone. The 50% load can be applied using an electric space heater (with no more than a 15 amp load to the plug socket circuit), which will also keep you warm while you sit there watching TV or catching up on email, or run the electric convection oven if you have one set to 350 or 400 degrees. Exercise the generator for a good hour.
From Mark Polk, prolific author of RV Education 101: "The first thing you need to understand about maintaining your generator is that they need to be exercised on a regular basis."
RV Generators 101 - RV UNIVERSITY
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
Old 11-09-2017, 05:28 PM   #10
Hoglou's Avatar
mice
We use about 10 of these around the coach.. a fellow rver I know uses Sam's dryer sheets and claims the same effect, but they dont smell as nice...
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
batteries
