Old 04-09-2015, 08:30 AM   #1
House batteries
2014 Sunseeker 3010DS going on a 6 hrs trip to Bullhead City, AZ. from San Diego, CA my house batteries are 3/4 charged will they keeping charging was I drive on the trip or do I need to plug in the charge batteries before the trip?
goots is offline   Reply With Quote
Old 04-09-2015, 08:57 AM   #2
The house batteries will charge on the trip as long as everything is functioning as designed. I would also make sure the house battery disconnect switch is in the on position. I think it will charge with the switch off but no harm in leaving it on. You can check that it is charging by checking your battery monitor a few minutes after starting the engine. The monitor should show full if it is charging.
ATVer is offline   Reply With Quote
battery
